TD6 Operation leave gas on?
just turn off after started (If it even works)it only holds 15 min of CRAP gas,and will be on the ground 99% ,with ANY procedure.
for shut off, if all else is good,you just need to leave the little valves in diesel to cool slowly.
CRAP gas is not going to give/leave you anything next go.regardless of manuals or gossip,short of $50 G real gas and EVERYTHING else 100%
My apologies I dont think I explained myself very well. After startup is there a reason to shut off the gas valve after switching to diesel for use and then turn it back on to let the engine run on gas just before shutting down? Or should I just leave the gas valve open when using?
It's not how the manual states but after gas start and successfully switching to diesel I close the gas tank petcock, then once your done using it I idle it down on diesel for cooling for at least 5 mins  before shutting off the machine, so I only use gas for the starting portion
If you've ever had one get gas on the diesel side, you'll shut it off.
