JB Freeman Posted September 16 Share Posted September 16 I’ve recently acquired a Series 1000 3 bottom plow. I’m trying to find an operators manual but so far have only found a parts manual. The rear furrow wheel is frozen up, and it’s missing all 3 of the Coulter wheels and holders. But it is a beast, appears to be a 1966-68 as the steel main frame is 3/4” by 2” solid steel bar. Any and all help is appreciated. 1 Quote Link to comment Share on other sites More sharing options...
HydroTek Posted September 17 Share Posted September 17 Set the RH wheel -- PTO to inside of the tire to 26" for 14" bottoms , or 28" for 16" bottoms you can determine which you have by measuring the path line between the points looking at your second pic -- measure from the first share to the path of the second share -- this gives the plow size use a stick or straight edge if that would help Set the plow level side to side when the tractor tire is in the furrow -- and level front to rear, to slightly down in front -- or set the LH tire (front and rear) on blocks to represent your plowing depth -- usually 6-8 inches and level across the plow --Adjust the top link so that the plow sits level front to rear When you get to the field and are plowing check the adjustments again , since slack in your linkages may allow the plow to move out of level Be sure to loose the sway bars so the plow can swing side to side freely -- do limit so it does not contact the tires tho Quote Link to comment Share on other sites More sharing options...
Rainman Posted September 17 Share Posted September 17 Mike Becker "The Paper Farmer" might have an operator manual...715-726-1942 1 Quote Link to comment Share on other sites More sharing options...
JB Freeman Posted September 17 Author Share Posted September 17 Thanks HydroTek, but I still have the frozen up rear wheel to contend with, plan on torching it off this coming weekend as the inside nuts are already rusted away by 50%. Quote Link to comment Share on other sites More sharing options...
JB Freeman Posted September 17 Author Share Posted September 17 Rainman, thanks I’ve check his EBay account he doesn’t show one but I did reach out to him concerning my plow Quote Link to comment Share on other sites More sharing options...
brahamfireman Posted September 18 Share Posted September 18 18 hours ago, JB Freeman said: Rainman, thanks I’ve check his EBay account he doesn’t show one but I did reach out to him concerning my plow Mike is the best, he'll look for a long time trying to find stuff. I just bought 2 operators manuals from him Sunday at the tractor show. 1 Quote Link to comment Share on other sites More sharing options...
JB Freeman Posted September 29 Author Share Posted September 29 Mike Becker (Paper Farmer) was very helpful and got me an Operators manual for my Case Series 1000 Bottom plow. Still having a hard time finding the Coulters that are missing but did get the Rolling Landside wheel off a part. New bearings and seals are on ordered. Just need to find the right Red Paint for my 1968 Plow 1 Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted September 29 Share Posted September 29 I think you want "Flambeau Red" for 1968. 1 Quote Link to comment Share on other sites More sharing options...
JB Freeman Posted October 13 Author Share Posted October 13 I finally received the wheel bearings and seal for the landwheel. Pull the Shin and Share off the center plow to get the replacements in to ensure they were the right ones. The replacements showed up today, they are the correct ones for my plow so I ordered 2 more of each for the 1st and 3rd plow. Hope to post pictures soon. Quote Link to comment Share on other sites More sharing options...
