davo727 Posted September 14 Share Posted September 14 Hey like to find out what else could be used if needed to swap in place of neuss d239. Diesel or gas doesnt matter. Even 6 cylinder alternative on the 674 since theres no frame or anything in the way. My ( 574 ) is actually a 250A backhoe so only a 4 cylinder would be feasible. Diesel would need to be something with an easily serviced and available injection pump. Thanks. Quote Link to comment Share on other sites More sharing options...
oleman Posted September 14 Share Posted September 14 Currently a 454 4 cyl gasser on an upcoming purplewave auction. Actually a very nice looking machine. Very little difference between the 454 and the rest of the family but it has no side rails. Believe it came with a d179 3 cyl version of the D239 4 cyl or a C200 gasser. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted September 14 Share Posted September 14 What else can be used? Not much. Just engines from the same family of tractors. 74 series, 84 series, 85 series, 95 series. After that they get too new and too few to really show up in salvage yards. At least, not without serious custom modification which you would be entirely on your own to figure out and perform. D268, D246, D239 of course, D206, C200 gas (but you may need some parts off a gas tractor) Quote Link to comment Share on other sites More sharing options...
TomH Posted September 14 Share Posted September 14 Can you use a Perkins from the C series? Its pretty much the same Doncaster tractor behind the engine I believe. Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted September 14 Share Posted September 14 20 hours ago, davo727 said: Hey like to find out what else could be used if needed to swap in place of neuss d239. Diesel or gas doesnt matter. Even 6 cylinder alternative on the 674 since theres no frame or anything in the way. My ( 574 ) is actually a 250A backhoe so only a 4 cylinder would be feasible. Diesel would need to be something with an easily serviced and available injection pump. Thanks. Forget 6 cylinder just isn't gonna happen ,Go with the same family of four cylinder engines unless you want to pull your hair out Quote Link to comment Share on other sites More sharing options...
davo727 Posted September 15 Author Share Posted September 15 Interesting, Thanks. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted September 15 Share Posted September 15 18 hours ago, TomH said: Can you use a Perkins from the C series? Its pretty much the same Doncaster tractor behind the engine I believe. I am betting they're computerized to some degree so it would be a lot more work than its worth. It's amazing how long they used that basic Doncaster platform. Even longer than the 06 series. 1 Quote Link to comment Share on other sites More sharing options...
acem Posted September 15 Share Posted September 15 I've seen small block Chevy's put in everything. But in this case a V6 would probably fit better. Quote Link to comment Share on other sites More sharing options...
