Justintime Posted September 19 Author Share Posted September 19 16 minutes ago, Rawleigh99 said: Well, there are only two possibilities I see. Engine rear seal or transmission seal. You could send a sample to Blackstone labs and see if they can determine if it is engine oil or transmission oil, I guess. Does it smell like either fluid? Unfortunately either one means pulling the engine. As long as the clutch isn't slipping I would use it while monitoring the fluids and see if either level drops. Is there a drain plug in the bottom of the clutch housing? If so, you could wash it out. It might make it easier to find the leak. I think, its the transmission because when I unintentionally drained the clutch housing (because of the leak) the oil had some water in it. The transmission, which I just drained also had some water in it. Also the engine oil is still full at the moment. This is thus far my best guess... but we will see. What would I use to clean out the area? Quote Link to comment Share on other sites More sharing options...
hillman Posted September 19 Share Posted September 19 welcome to the fun part of old iron, Quote Link to comment Share on other sites More sharing options...
Justintime Posted September 19 Author Share Posted September 19 15 minutes ago, hillman said: welcome to the fun part of old iron, I will say it is a learning experience for sure. Any thoughts on how I would clean out the clutch housing? I can drain everything out the bottom but what about any gunk on the walls? Quote Link to comment Share on other sites More sharing options...
louie figone Posted September 19 Share Posted September 19 Power washer with the drain plug out, then lube all the fittings and work the tractor to get it hot in there. Is this a bare tractor, loader, bulldozer? Quote Link to comment Share on other sites More sharing options...
Justintime Posted September 20 Author Share Posted September 20 5 hours ago, louie figone said: Power washer with the drain plug out, then lube all the fittings and work the tractor to get it hot in there. Is this a bare tractor, loader, bulldozer? It's a bulldozer. Confirmed the leak is coming from the transmission. I was flushing the transmission with diesel and diesel ended up in the clutch housing. Not a ton but enough to get it wet Quote Link to comment Share on other sites More sharing options...
mmi Posted September 20 Share Posted September 20 good time to use the KOO method and change seal/bearing Quote Link to comment Share on other sites More sharing options...
Justintime Posted September 20 Author Share Posted September 20 I've searched through his website but couldn't find it. Do you have the direct link by chance to these steps? Quote Link to comment Share on other sites More sharing options...
mmi Posted September 21 Share Posted September 21 free site = poor search,get an idea here and search outside and then read/search koo s posts https://www.google.com/search?client=firefox-b-1-d&q=koo+red+power+td9+clutch https://www.redpowermagazine.com/forums/search/?&q=king of obsolete&type=core_members&joinedDate=any&group[4]=1&group[5]=1&group[3]=1 1 Quote Link to comment Share on other sites More sharing options...
Tad Wicks Posted October 3 Share Posted October 3 all oily and gooey is far better than being rusted tight. Quote Link to comment Share on other sites More sharing options...
