creeping charlie in yard
gh-in-oh
Anyone have this in their yard?  I believe it is in the mint family.   I am not one to get to excited about a yard, but this stuff is really taking over.  Roundup will kill it, but it gets grass too (as you know).    2-4-d will not touch it.    Any suggestions would be appreciated.  Thanks.
Struggling with this as well. I believe millstone (crossbow? Among others?) and it's variants will kill Charlie, bit there is residual..so don't use the clippings around any sensitive plants or garden type plants. I have a large patch but some of it is uphill from my garden and I'm not crazy about any runoff getting into my food supply....
Just now, Thomas848 said:
This is said to be about the best cocktail  for the stuff  Hope it is of value.
The most effective broadleaf herbicide for creeping Charlie contains triclopyr, generally in combination with 2, 4-D, and Dicamba. Standard herbicides without these components won't work as well.
Something got lost :{
Scott’s Spring and fall weed and feed works pretty good for me for 2 seasons but it will come back eventually
I had to look it up, that chit is everywhere at my grandmothers house, only thing that seems to choke it out is myrtle, which is everywhere else. My parents, across the street has none whatsoever.
Multiple applications spaced apart with a combination mix with dicamba. Will be an on going battle to keep under control....
As others have mentioned 2 4-d and Dicamba sprayed in the fall work good.  Later in the fall when it's starting to get cool at night is when you have the best results.  If you have it really think I would do 2 applications, spray once and then hit it again in a week.  Both Crossbow and Grazon do a good job too.
Par III here in Canada,  smokes a lot of the weeds and leaves grass behind.
Do agree,  it stinks when cut and takes over.  Nasty ass weed.
