2023 pulling season recap
Power of Red
@F-301066460puller
Dont you worry, governor delete had already crossed my mind. I have an ih carb from i think from a 460 that bolts right up for an  easy dead man throttle upgrade. Was thinking adding a rev limiter set to 2k. And adding a spring resitance i can feel in the lever once the free unloaded engine hits around 1700 rpm then i can mash in harder as i hear my rpm drop... but that means i would need to jump up to the open class. Aka need wheelie bars and even more horspower.  Its a stalemate debate.  I will try to get some slop out of my governor first. Then go from there. Machining parts if fun!
