Off color alternator question-Oliver
CDN 400
On my 656 I unplugged the voltage regulator, made two jumper wires, connected the outer wires together and connected the inner wires together on the plug. At the alternator you need to determine which wire is now connected to the indicator lite and connect it to the #1 wire of the alternator and connect the other wire to the other lug.
