Nice job,awesome
2 hours ago, TroyDairy said:
Nice!
I dont get how you guys can afford to fix these gals up!  Everything is so nuts nowdays $wise
TD, it's only the dairy guys that can do it, 😁 have you seen the price on moo juice at the store lately?
1 hour ago, Matt Kirsch said:
That detracts from the value of the tractor by $165,000.
I prefer not to install them. But also at the same time I do not use the screws or bolts provided to attach them to the sheet metal.  Won't rattle or become loose and make a rust hole either.
On 9/5/2023 at 5:06 PM, IHC5488 said:
I see that you have the cab skin off in one piece, could you ever explain how you did that? I'm rebuilding a 5088,and haven't figured out how I'm going to paint thecab yet.
Everything comes out or off.
Headliner, radio, speakers, AC panel, dome light, front bezel, side trims, rear window hinge, side window hinges, wiper motor bolts, rear fender bolts, flasher lights, rear cab filter, spring clips in filter box, screws down back cab pillars,  2 headliner flat stock steel in roof access,   if you see a screw or bolt remove it!  All your plumbing, AC lines, wiring doesn't need removed.
I think I listed everything.
