Tips for installing duals?
rrr4quality
Hay field is pretty soft. To help mitigate damage I thought I would put the duals on the 1066. I’ve never had them on before. My thoughts are drive the tractor up on a couple short boards and then use the forks to put the dual on. Sounds easier than it is probably going to be. Any other suggestions?
We jack one side up slightly, use a line up dowel and then lean the tire up using a ground bar to line up the hole . On Magnum duals we have always timed the valve stem at the same place so inner is easy to find by looking at the dual. They have a hole in the rim opposite of the valve and we park tractor with the hole up and set dual with a small chain or strap in place to finish it with the bar
Bottle jack is much easier than a couple boards. Just get the tractor high enough to allow the rim to align so the bolts can start properly. After you get them started and the top one or two tight you can raise the jack to clear the dual and torque the bolts. Be careful!
Do you have axle mount duals or are they the clamp on style duals?
Did this with 3 tractors when I was young.  I’m in spring off for winter every year
best tip is find concrete or a smooth level surface
bottle jack over boards every time
a long bar or 2x4 is great to stick under a lug while you hold the wheel in the center so you can spin the tire on the hub to line up the holes
Band duals is the same idea. I did two sets of each style every year for a Long time. I put a few dabs of grease or oil on the band at the Bottom, let’s the dual pivot/spin much easier   when you index it.  I would put both valve stems Up, less chance of slipping and hitting or dropping something on one.
driving up on boards works   but doing it for the first time, the jack will be easier
As others said much easier with bottle jack and a line up dowel.  You can make a dowel by cutting the head off a bolt and cutting a screwdriver slot.  I also made a heavy duty jack stand to put the bottle jack on so you can put the jack under the axle housing.
We used to do it with a bottle jack and a spud bar to spin it to get the bolt holes to line up. Never had a dowel made up to line up ( should have, but didn't) did 2 tractors every year this way.
A few years back now I bought one of the Bierman easy dual changers. I have to say, Man that thing is slick. Lift with your front end loader of whatever you want and it has wheels so you can roll it into position to line bolt holes up. Even have a couple of neighbors we trust that that borrow it to use.
From the sounds of it though this isn’t too often of a occurence so probably don't want to put the money into one but the option is out there.
Few pictures of the product from online because im not near them.
For hub duals, I always use the wood block and one of these 30" OTC aligning bars.... get the dual close, stick the bar through the uppermost lug hole in the dual and hub. Give a little lift and push, stick a bolt in.Screenshot_20230903-133335_SamsungInternet.thumb.jpg.92c9f02f333bf25f7762da6ee61e5efa.jpg
I have one just like that only it says Case IH on it. That’s what I use.
So easy even Crooked Joe can use it
38 minutes ago, rrr4quality said:
First one went on real easy, second one took a bit to line up. Thanks guys for your advice!63A34E53-2575-4962-9F00-55CA1637EAC5.thumb.jpeg.0ed9f33fbc2e2b6a9dde5cc8624de93c.jpeg
You never mentioned it was a black stripe 10! Now you went and did it- everyone is gonna want to see a picture of the tractor. It looks like a nice one from what I can see of it!
i thot you just folded your arms, nodded and blinked and they went on - but the rest of the time i use a board and drive the tractor up on it, use a steel post in center of the dual to tip it up high enough to get a bolt or two started and viola' but hey what do i know - mine are hub mounted and i never have any help other than lurkers out the window
