IH 2455 MOUNT-O-MATIC
Long Farms
18 minutes ago, HydroTek said:
Extra reach with the mounting that far to the front -- should be mounted back on the transmission pads
Negative. Mounted where the manual says to mount it and where factory drilled holes are. Mounts in same exact spot as every other 2350, 2355 and 2450 does
9 minutes ago, HydroTek said:
None that I ever seen , has that much frame sticking out in front of the radiator
He has it mounted correctly. Those loaders were made for the 88 series tractors which were longer and wider. We have a 2355 that was on our 1256 and it was the same way. Nice thing with that was you could leave the front weights on as you can see.  We got a 2450 loader to replace it and it’s definitely a bigger loader but it’s nice to have the extra lift height.
2455 should also have better front wheel clearance than 2450. The 55 series loaders came along after 4wd started to gain popularity and the 55 loaders were designed to have better front wheel clearance than the 50 series to accommodate the larger wheels..
