Farmall1066 Posted August 14 Share Posted August 14 Working on an 826 GD, and I found this #2 on the underside of the main hood, written with a black marker. A friend of mine has, if I remember correctly #17, or #19 on the underside of his 826 GD hood, what do these numbers indicate? Did all the Gold Demos have a number on the underside of the hood? This particular 826 is serial number 14041, so it’s nearing the end of the 70 model year run of production. @Bermuda_Ken 1 Quote Link to comment Share on other sites More sharing options...
acem Posted August 14 Share Posted August 14 Never had the hood off mine. I'll try to look and see with it on. Quote Link to comment Share on other sites More sharing options...
Farmall1066 Posted August 14 Author Share Posted August 14 6 minutes ago, acem said: Never had the hood off mine. I'll try to look and see with it on. It’s over the fuel tank, and the heat baffle with block your view. 1 Quote Link to comment Share on other sites More sharing options...
iowaboy1965 Posted August 15 Share Posted August 15 12 hours ago, Farmall1066 said: Working on an 826 GD, and I found this #2 on the underside of the main hood, written with a black marker. A friend of mine has, if I remember correctly #17, or #19 on the underside of his 826 GD hood, what do these numbers indicate? Did all the Gold Demos have a number on the underside of the hood? This particular 826 is serial number 14041, so it’s nearing the end of the 70 model year run of production. @Bermuda_Ken That's an interesting question! Quote Link to comment Share on other sites More sharing options...
INTERNATIONAL 1466 Posted August 15 Share Posted August 15 Never noticed that on our 1456. It is interesting for sure. Quote Link to comment Share on other sites More sharing options...
Farmall1066 Posted August 15 Author Share Posted August 15 7 hours ago, INTERNATIONAL 1466 said: Never noticed that on our 1456. It is interesting for sure. It seems as though it may only be an 826 thing, so that really makes it interesting. 8 hours ago, iowaboy1965 said: That's an interesting question! We may never get an answer as to what these numbers represent, but it would be another piece of history unlocked if we can find out! Quote Link to comment Share on other sites More sharing options...
SD6788 Posted August 21 Share Posted August 21 So I have had 8-10 demonstrators and all of them had numbers written on them in the exact same spot. Mr. Updike told me he believed it was line build numbers as they were being built at the plant. Quote Link to comment Share on other sites More sharing options...
Farmall1066 Posted August 21 Author Share Posted August 21 8 hours ago, SD6788 said: So I have had 8-10 demonstrators and all of them had numbers written on them in the exact same spot. Mr. Updike told me he believed it was line build numbers as they were being built at the plant. Line build numbers, so would that indicate how many were built per day, or per week possibly? Quote Link to comment Share on other sites More sharing options...
Jacka Posted August 21 Share Posted August 21 10 hours ago, SD6788 said: So I have had 8-10 demonstrators and all of them had numbers written on them in the exact same spot. Mr. Updike told me he believed it was line build numbers as they were being built at the plant. Do you still have them and did you have one of each model. Quote Link to comment Share on other sites More sharing options...
