DPF burn cycle questions?
vtfireman85
While running the backhoe today it beeped and showed an exhaust filter symbol and “on” underneath, I continued running it at 1500 as I had been because I suspected it shouldn’t be shut down, it beeped snd flashed the symbol a couple more times over 10-15 minutes, then it showed the symbol and “off” and didn’t do it again all day. Did it do a burn cycle and its all good now? What should I have done differently? Any information would be great.
likely so, my deere Compact Tractor = light comes on, you have to keep running it, it wont even shut off IIRC i think i tried that once, if you try to lower the idle it will not lower below a certain point it runs the idle up to do what it needs to do, it takes mine around 30 mins when it comes on while I am cutting the grass to go back down to 0%
Although I am not familiar with DPF systems on construction equipment, generally a symbol like the one you showed indicates exhaust temps are high.
Is there an operators manual? Or decals on a nearby sun visor, or sidewall?
My 3038 jd dad bought new does the same.  Turn the key off, remove the key, it will still run until the burnout is done.  And burn nearly a half a tank of fuel to do it....
As others mentioned. That’s normal operation. The symbol you showed is to tell you the exhaust is very hot so you avoid combustable materials while the regen is running
Matt
Yup. Sounds normal. You did the right thing revving the motor up. They need heat to burn out properly. I keep after dad not to idle the skid steer around while it’s doing it’s thing.  So far hasn't caused any issues but im sure the day is coming.
On my CAT 329E hoe, it shows a percentage of how full the DPF is before I need to do a manual burn. When I first got it, I thought it would do it automatically as I was operating the controls. Well, I needed to keep digging a pipeline in, as there was 5 guys waiting around on me. So I kept going. DPF percentage got to 115% and then derated me. I couldn’t even do a manual burn to it as the CAT service tech talked like I should. Found out, once you hit 115%, CAT has to come out and hookup their computer to do the burn and reset it.  Expensive mistake I guess you could put it. So I always burn it manually when I see it getting to about 70%. I realize not every machine is set up this way, and may not even show you the percentage. I guess I’m giving out free advice to anyone who sees the light on for awhile to just make a quick phone call to their service guy before you wait too long and need a on-site service call like I did.
Friends have a NH excavator that they plugged the DPF in, it was similarly inconvenient and very expensive, I almost think it needed to be replaced.
It is a PDF ( short for PITA) 20 miles away on a computer.
10 hours ago, vtfireman85 said:
Symbol looked a bit like this.
Why do they use indistinguishable symbols?
What is wrong with English?
Storing PDFs of frequently used operators manuals (vehicle, tractor, attachments, etc) doesn’t take up much room on a smartphone and then they’re always handy. New things are getting complicated and have so many features it’s good to have a book to look up how they work or what different warning lights may mean.
After awhile the DPF symbol will be common enough that everyone will know what it means. An oil pressure symbol or seat belt light or battery light makes sense to all of us because we’ve seen them for years and years.
Some of my fleet is so old the oil light has a genie coming out of it. 🧞‍♂️
Bit of advice for everyone running emissions compliant diesels....
Talk to the service department at the dealer, educate yourself on what indicators mean what...!
Most of the time, the emissions equipment is made to run in the background and you don't have to worry about it. But a lot of the time, it requires the machine being operated in a certain way.
An example, there's probably quite a few people here who run Cat D series skidloaders, but few who know this about them... The throttle dial has a green zone from about 50% up. If you always run the machine with the throttle in that green zone, it will regen on its own during normal operation. If you run it below that, it will need a parked regen from time to time.
I would say 1/3 of the emissions related problems we repair are operator induced. People spend thousands of dollars repairing things that would have been fine had they simply paid attention to the light on the dash and known what it meant.
Is that the oil light or the magic smoke light?  You don’t want to let the magic smoke out, it’s difficult to get back in there.
You mean read the manual? We're men we don't ask for directions either!
I'm so old I can recall when an oil light actually said OIL!!! These new universal symbols aren't really. 🙄 I would have no idea what the symbol above meant if I saw it.
The straight things are bullets, the dots are the people of the United States, and the semicircles are the economy going up in smoke.
Global economy = symbols instead of words. One dashboard for all locations. Even a basic passenger car has dozens of warning lamps now.
There are websites for dashboard warning lights, quite a few symbols to memorize.
https://dashboardsymbols.com/2011/08/diesel-particulate-filter-dpf-warning-symbol-indicators/
yes agreed 100% when mine wouldnt shut off on my deere i got to looking at the book and as stated here just run it, personally i dont keep it at fully throttle anymore than i do my D series skidloader - i know someone said things are made to run WOT but i am more of an 80% guy - not sure if im hurting or not hurting things but its been a lifelong habit i just never got past - i know im not mechanical but i cant go 100% for very long
i keep my book in the same spot i received it from the dealer, BEHIND THE SEAT and when i dont know what is going on i get the book out and read - things are far too expensive to be breaking/tearing up these days so anything I can do to help with that i certainly try. and usually before the book comes out i am praying i hope i didnt tear something up
Ya I am aware. Just means we can be confused world wide by vague symbols that are not self explanatory most times. Another reason I am not a fan of glo bull anything.
I have run the D series and was aware of that.
The D CAT skid steers have worked in me a burning and lifelong hatred for fly-by-wire machinery.  My brother is on his second CAT 226D and the software on both machines  make them THEE most miserable handling machine I have ever run.  Just miserable.  If I ever catch the software engineer that wrote the programing for those machines I will probably do jail time after that meeting . . . That and they used crap potentiometers for the controls . . .
Never been in anything but our B series, but its a nicely built piece of equipment, i am surprised to hear complaints about CAT quality.
Cat isn't what it used to be.  Our county as been running Cat graders forever but last several have been problematic to the point one was traded for a JD a couple years ago.  Also have one Case grader.
