Geoff_in_MN Posted August 5 Share Posted August 5 (edited) Nothing wrong with the tractor really. I've got a decent manual for this thing, and nowhere does it show the light pictured. Anybody else have this light, or was it an add-on? Edited August 7 by Geoff_in_MN Update Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted August 5 Share Posted August 5 Looks like an add-on never seen a light in that spot before Does it ever come on? Quote Link to comment Share on other sites More sharing options...
HydroTek Posted August 5 Share Posted August 5 Hydrostat drive on this tractor ? Quote Link to comment Share on other sites More sharing options...
Geoff_in_MN Posted August 5 Author Share Posted August 5 (edited) Yes hydro. Yes it comes on and lately just constant. I'm thinking just a light to indicate key "on". It has an add-on fuse holder as well. Edited August 5 by Geoff_in_MN Info Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted August 5 Share Posted August 5 8 minutes ago, Geoff_in_MN said: Yes hydro. Yes it comes on and lately just constant. I'm thinking just a light to indicate key "on". It has an add-on fuse holder as well. Ahhhh Hydro well you didn't disclose that info its maybe the charge pressure light Quote Link to comment Share on other sites More sharing options...
HydroTek Posted August 5 Share Posted August 5 That is a high oil temp light -- it should only come on if the oil is hot Check the sender wire to be sure there are no bare spots Left side behind the starter on the MCV 1 Quote Link to comment Share on other sites More sharing options...
Geoff_in_MN Posted August 6 Author Share Posted August 6 1 hour ago, HydroTek said: That is a high oil temp light -- it should only come on if the oil is hot Check the sender wire to be sure there are no bare spots Left side behind the starter on the MCV Not seeing any wires there... Quote Link to comment Share on other sites More sharing options...
Mild Bill Posted August 6 Share Posted August 6 If I recall correctly... I think our 756 diesel had that light and it was a key on light, that came on if the key was on but the engine was not running. The 756 has sold at my folks machinery auction roughly 20 years ago. but maybe it was used for different purposes on different models. 1 Quote Link to comment Share on other sites More sharing options...
snoshoe Posted August 6 Share Posted August 6 Buried in gunk left side mcv right side tractor 1 1 Quote Link to comment Share on other sites More sharing options...
Jacka Posted August 6 Share Posted August 6 We had one on a 656.I think if key is on and tractor not running it was on.Also maybe blinked on and off until warmed up but been 45 years since it left the farm Quote Link to comment Share on other sites More sharing options...
HydroTek Posted August 6 Share Posted August 6 High temp light -- it should not be on any other time 1 1 Quote Link to comment Share on other sites More sharing options...
Jacka Posted August 6 Share Posted August 6 36 minutes ago, HydroTek said: High temp light -- it should not be on any other time At what hyd oil temp does it come on. Quote Link to comment Share on other sites More sharing options...
Geoff_in_MN Posted August 6 Author Share Posted August 6 2 hours ago, HydroTek said: High temp light -- it should not be on any other time Not saying you're wrong, but it seems to be on constantly now even when starting up cold. I'm gonna do some checking and trace some wires. Quote Link to comment Share on other sites More sharing options...
snoshoe Posted August 6 Share Posted August 6 Just unhook the sender. Light still on? Wire grounded. Light off? Sender bad. 2 Quote Link to comment Share on other sites More sharing options...
snoshoe Posted August 6 Share Posted August 6 5 hours ago, Jacka said: At what hyd oil temp does it come on. Don't really know but since max temp is 100 over ambient. I would think 180-190. Quote Link to comment Share on other sites More sharing options...
Geoff_in_MN Posted August 7 Author Share Posted August 7 Found it! Took some disassembly but I found the sending unit. HydroTek and snoshoe were absolutely correct. Wire to high temp sending unit was grounding out in 2 spots. What is puzzling to me is the factory operator's manual gives no indication of a light or a sending unit despite having fairly detailed schematics and photos of the various 656 dash layouts. I took the wire with connectors out for the time being. May or may not replace it in the future. At least it's documented here for the time being. Thanks fellas! 3 Quote Link to comment Share on other sites More sharing options...
HydroTek Posted August 8 Share Posted August 8 Glad you got it figured out I have the International model , a lot less room to work in that area Only time I ever had the light come on was pulling a 12 foot disk mostly just use the tractor for brush hogging and loading round bales out of the field now days 1 1 Quote Link to comment Share on other sites More sharing options...
Diesel Doctor Posted August 8 Share Posted August 8 I looked and that light is not shown in the Case/IH parts diagram for the 656. It must be a figment of our imagination? 1 Quote Link to comment Share on other sites More sharing options...
chadd Posted August 8 Share Posted August 8 Could it have originally been tied to the same tell light in the cluster gauge as engine oil pressure? I don't remember a light there on our 656 hydro. On our 806, the MCV press and engine oil press use the same light. Quote Link to comment Share on other sites More sharing options...
Youngch72 Posted August 11 Share Posted August 11 Hydraulic dump valve light should only be on when clutch is engaged. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted August 11 Share Posted August 11 3 hours ago, Youngch72 said: Hydraulic dump valve light should only be on when clutch is engaged. No dump valve on a 656. Quote Link to comment Share on other sites More sharing options...
Maynard Posted August 12 Share Posted August 12 18 hours ago, Youngch72 said: Hydraulic dump valve light should only be on when clutch is engaged. 15 hours ago, Matt Kirsch said: No dump valve on a 656. Correct, the dump valve was used on foot controlled models, the hand controlled models used the Foot-N-Inch valve that allowed feathering of the drive via the foot pedal. Quote Link to comment Share on other sites More sharing options...
