Adding 3rd lift cylinder to 1680
Debmar
Want to swap a 3rd lift cylinder from a parts combine to a 1680 with only 2.  I need a T to put into my hydraulic lines under feeder house but would like to have the parts on hand prior to doing so .  Can’t use the parts from the parts combine as they are set up differently and just getting a T will be easier.   I never know right name or term for different hydraulic fitting types.  What type of hydraulic fittings are used on these combines so I can just ask the hydraulic shop for what I need.
usually i would just take example with me but it would be cleaner to just have what i need there when i dismantle the existing line
Thanks for the help.
Martin
PS:  any good link or resource suggestion to maybe print and hang on wall in the shop to enable us to learn the different types?
Unfortunately, all of them.
It could be ORB (o-ring boss), JIC (37 degree flare) or NPT (national pipe taper) and then any of three different sizes of each. For example, the cylinders on my 2350 loader are ORB at the cylinders, convert to JIC in the elbow connected directly to the cylinder, and has NPT threads on the ends of the hoses with the coupler nipples.
Yup. I just checked the parts book and they use ORB at the cylinder itself, into an elbow that converts to JIC. The book calls it "3/4-16" which I believe is actually "half-inch hose" or "dash 8" sized fittings.
Also according to the parts book the port for the third cylinder should already be there. The cap labeled "12" on this diagram:
10 minutes ago, HydroTek said:
That 3rd cylinder was connected to the accumulator , to act as a spring
The accumulator is connected to all cylinders at least it is on my 1400 series combine and Deere's
Check again -- the 3rd cylinder is connected to the accumulator -- not the other 2
there is valving under the cab behind the wheel to set the function of that 3rd cylinder and accumulator
Adding a 3rd cylinder into the existing circuit will slow the head lift by 1/3
Must be on the later combines  because 1400 series combines have all cylinders  from the accumulator for header float Same on Deere's too
Sure looks like all cylinders are on the same line to me and anytime you have an additional cylinder its naturally going to lift slower because it displaces more oil but for the accumulator to work properly  they all must be on the same line
Somewhere in the past i guess someone messed with the setup on my 1680 with only 2 cylinders as there is no existing  capped T .
donor combine is set up that way and matches diagram.  The 2 cylinder machine definitely responds faster than the 3’s which makes sense but it is also weak and unable to fully lift a 30’ 1020.  The 2 is actually a problem when using auto header height control and too much response too quickly.
thanks for responses, that will help me figure out what i need after some more digging into it.
but i think the one link indicated looks like the correct T
There was one iteration of the 2-cylinder setup that I missed in the parts book, which does not have the capped tee. It's the version with the hose supplying the cylinders all the way from the valves. No hard lines.
