Young mechanic Posted August 4 Share Posted August 4 Has anyone put or seen a coolant filter on a d-239? Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted August 4 Share Posted August 4 23 minutes ago, Young mechanic said: Has anyone put or seen a coolant filter on a d-239? Why do you think you need one? Quote Link to comment Share on other sites More sharing options...
Wisconsin Ron Posted August 4 Share Posted August 4 Yes we installed one on our farmall 544. Quote Link to comment Share on other sites More sharing options...
HydroTek Posted August 4 Share Posted August 4 I have -- you can use the same setup that was used on the D-358 in the "88 series tractors tho the mounting bracket may need to be modified, since the 4 cylinder is shorter The filter was not typically used on the 4 cylinder engines tho -- Are you cleaning up a dirty system ? Quote Link to comment Share on other sites More sharing options...
R190 Posted August 4 Share Posted August 4 I put one on my uncles 574 when we had to overhaul the engine in the early 80s because of cavitation issues. Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted August 4 Share Posted August 4 You can put additives in the system for cavatiation problems Why buy another high priced fllter ? if guys service the cooling system more regular you'd never have a problem to begin with I've seen these older tractors with antifreeze so old in looks like chocolate milk ,There's your problem Quote Link to comment Share on other sites More sharing options...
Young mechanic Posted August 4 Author Share Posted August 4 There's just a lot of crappy rust looking stuff in the motor would like to clean it up Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted August 4 Share Posted August 4 1 minute ago, Young mechanic said: There's just a lot of crappy rust looking stuff in the motor would like to clean it up Drain it flush it out of every hole and radiator , start with new coolant and add conditioner Quote Link to comment Share on other sites More sharing options...
Young mechanic Posted August 4 Author Share Posted August 4 Use soap to flush it out or what Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted August 4 Share Posted August 4 I never recommend using soap Just good clean water til it runs clear nothing special then A good quality antifreeze and conditioner , I change and flush the cooling System about every 3 yrs been doing it all my life on tractors of all ages never ever had a cavitation problem Quote Link to comment Share on other sites More sharing options...
oleman Posted August 5 Share Posted August 5 WIX has/had a had a universal coolant filter base and several types of filters available. We got ours in 2008 via Rock Auto. Quote Link to comment Share on other sites More sharing options...
steelerhawk Posted August 8 Share Posted August 8 Fleetguard makes a great 2-step flush to clean that system thoroughly. Restore and Restore Plus. When clean, refill with a SCA-precharged coolant, like Fleetguard. The add a bottle of Baldwin BTA PLUS every year. 1 Quote Link to comment Share on other sites More sharing options...
