560Dennis Posted August 2 Share Posted August 2 The bushings in the seat are shot . Seat twist when I sit in it. isn’t there a kits available to fix them ? I haven’t looked yet cause I need to look around here, thought I saw some bushings in the shed . Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted August 2 Share Posted August 2 A pic of the type of seat you have would help Quote Link to comment Share on other sites More sharing options...
Drysleeves Posted August 2 Share Posted August 2 If it's the type with the pan seat and shock absorber suspension, I replaced mine a few years ago due to the same affliction. Quote Link to comment Share on other sites More sharing options...
560Dennis Posted August 2 Author Share Posted August 2 Pan type seat is what it is. Quote Link to comment Share on other sites More sharing options...
Binderoid Posted August 2 Share Posted August 2 58 minutes ago, 560Dennis said: The bushings in the seat are shot . Seat twist when I sit in it. isn’t there a kits available to fix them ? I haven’t looked yet cause I need to look around here, thought I saw some bushings in the shed . I have the same problem but I don’t know what it’s supposed to look like because someone before my time ran a pin through it and welded it on both ends. So I’m guessing when I suggest a Harris silent block from a 503 combine grain pan support lever. I thought it was 1/2” ID but that was 20 years ago.This appears to be , at least, the same relative size as that seat hinge. A quick search shows that there is quite a variety of canned rubber bushings to cover any application. Quote Link to comment Share on other sites More sharing options...
560Dennis Posted August 2 Author Share Posted August 2 Had some time , looked at the gates Corp. parts for C they have them . I got fix it before I land outside the saddle Quote Link to comment Share on other sites More sharing options...
