Cleaning spray foam from plastic
Acetone is the most effective at removing spray foam residue, but of course it ruins the plastic. Long story but my radio got encapsulated in spray foam, once dried most of it came off but residue remains, any suggestions?
Dip your finger in WD40 and dab it on the lens, let it soak on the screen and then gently rub the screen with your finger and if that don't work, carefully use your fingernail. The solvent in the WD40 should soften the spray foam and lubricate screen to lessen the chance of scratching it, depending on what type of spray foam that was used. I can't guarantee it will work, but it should not hurt the screen.
On anything I’m concerned about hurting, but need to clean grease off of, or sticky stuff, I use Citrol from Schaeffers. It smells like oranges, which is a downside for me, but that smell does wear off after awhile. I can put up with the smell, if it saves my item. Grease on clothes and carpet, sticker residue on vehicles and equipment, and tar on the new tractor. Citrol cleaned it all off, and never hurt the item I was trying to clean.
Ill try that in the morning, I don’t care about the rest of it, but the screen is hard to see in bright light and depending on what is going on I have to switch over to the other side back and forth, it’s annoying.
1 minute ago, mmi said:
call MFG Tech #
call MFG Tech #
I don’t speak Japanese..
Cousin has been there 35 yrs teaching them American in high school.......
USA distributor/importer should have info/solvent  if not part of the mSD
Sure its not Its not AFFF ,highly flammable and toxic from china, in a jap can?
I am gun shy about solvents, i had used terminal/contact cleaner many times, we had some malfunctioning pagers, i grabbed one, popped the battery out and hosed it down, next thing I know the whole thing is melting in my hand. Turns out only SOME contact cleaner is plastic safe 😬
6 hours ago, nomorejohndeere said:
can you remove the lens?
I think it is glued, this has a water resistant rating
Will a plastic safe electronic cleaner work?  Same stuff you can spray on weatherpack connectors without having them fall apart. I think my can at home is a “QD electronic cleaner” from CRC
I am scared
exact same thing happened to me
If it gets scratched maybe you can wet sand it up through 3000 grit and then polish it good.  Most auto parts stores have the sandpaper and polish.  Headlight cleaner may also help clear it up post cleaning.
IMG_2053.thumb.jpeg.5bd7ae6c94ab75bdee49cdfccb05da90.jpegWe use this at work. It takes most everything off and I have never had it melt plastic. Used to use it onthe hood of our race sleds to take sticker gunk off. Maybe worth a shot.
