DT436 Rings
SeanP
Overhauling a dt437. It must have been an early b series because it still has the original style crank and manual says to set intake valves at .020. What rings would you guys use? I have a top breather, a little blow by doesn’t bother me I just want a reliable well running tractor that doesn’t use oil. I’ve heard the blow by from the wide gap rings help lube the rocker arms? What is everybody using?
Cam not crank
