340 won't idle down
ny bill o
a friend used my 340 at our plow day in April. I didn't need it again until time to spray the corn, when I discovered that it won't idle down past about 15-1600 rpms. Any suggestions as to what the problem could be, other than the governor? Pushing on the throttle linkages makes no difference.
Picture was taken on one of those days when we had smoke from the Quebec wildfires.
21 hours ago, snoshoe said:
Does the throttle stop screw contact the stop? Other possibilities air leak or plugged idle fuel circuit.
I'll check those things later today. Thanks.
