5288 MFWD Propellor shaft
Yep, still does if front differential is still ok.
Posted (edited)
I will check in my book in a few hours if no one has given you an answer yet, but those are spring pressure to engage.  It takes enough hydraulic pressure to overcome the spring pressure to disengage.  I will look in my book and hopefully post a couple pictures from it to help you out.
Edited by Littlefeller
Clarification
That is for the solenoid, checking the rocker switch is pretty straightforward.  First I would make sure the driveshaft is turning while tractor is moving.  If not front end issue.  If it does turn and solenoid and switch are working, then the clutch for fwd is slipping.  Also check the splines on the driveshaft.  I may be wrong but I think sometimes they stripped the splines so driveshaft wouldn't engage front end, but dont remember positively
if it's not turning when the tractor is moving remove the driveshaft and check the splines on the shaft coming out of the rear of the tractor and front axle and the drive shaft itself, we had one 8 or so years ago one shaft was wore badly and apparently it's a pretty common issue from what i've seen since then. Normally if its a electrical issue the front axle won't disengage switch, fuse, wiring, etc.
This last winter my 5488 wouldn't engage mfwd. The solenoid valve under the cab was stuck open. I replaced it with a hydraforce valve for about half the cost the dealer wanted and all is well now.
7 hours ago, HydroTek said:
OP could take the line loose on the RH side of the tractor that operates the MFD -- with the switch ON, there should be no oil flowing
LH side.
Left, Right, Forward, Backward, Up, and Down are established by standing behind the machine, and facing the direction of normal travel
if you choose to stand in front of the machine you will be ran over , plowed under, or various other forms of demise .
Front and rear of engine and drivetrain are established by the power input and output -- Front on an engine would be the crank pulley end -- Rear on the front differential in an AWD machine would still be the diff cover .
2 hours ago, 5288IH said:
Also would it be easier to take tyre off. I hate taking tyres off
How wide are the tires set? I didn't take mine off but they're spaced fairly wide.
box manure spreaders being the exception to that rule😬
