DoubleJFarmsWA Posted June 29 Share Posted June 29 Does the hyd system have a breather? I pulled the drain plug to check for water in the hyd system (newer to me tractor). The system was under pressure. Also, is there a level plug, to know how full to fill it? Quote Link to comment Share on other sites More sharing options...
E160BHM Posted June 29 Share Posted June 29 There is no breather. With the lift arms to the rear, fill the reservoir until the oil just runs out of the fill hole. Brian. 1 Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted June 29 Share Posted June 29 Ah yes, remove the fill plug first or you end up wearing the contents of the reservoir. Been there done that. Quote Link to comment Share on other sites More sharing options...
