IH bearing cross reference
louie figone
that bearing is a tough one. not a lot of options in my books
West Pullman (WP) PL 240
New Departure made IH bearing- 20095d which appears to still be a good number
 Maybe someone else can find a better number or your bearing supplier can cross the numbers I found
Good luck
is it a ball bearing ?
2 hours ago, louie figone said:
Hillman, yes I found the link, I was unable to print it, it's me, I need to get my computer guy here to help me out. Thanks for all your help.
Louie
can you post the link, I would like to print one off if possible
Thank you
2009 SKF Interchange PDF
Should automatically download and open as a PDF in your browser - if so: Click "File" -> "Save Page As..." to save a copy to your computer under a file name of your choosing.
I'm sure there are other Interchanges to be had with some searching.
Mark
**Edit:
I should note - that PDF is about 450 pages....even if you print 'both side' of all your paper, I doubt you REALLY want to print it out?  You probably already know how to save it to disc rather than print, but I added that pointer just in case it might be found helpful.
End Edit**
Edited by DT361
additional info
