mader656 Posted June 20 Share Posted June 20 To bend drill stem by hitting the top? That was a narrow but hard rock. 1 Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted June 20 Share Posted June 20 I presume this is for a fence as I see the wire in the grass. Are you using it for an anchor or have you developed a way to attach wire to it? Quote Link to comment Share on other sites More sharing options...
mader656 Posted June 22 Author Share Posted June 22 On 6/20/2023 at 12:57 PM, MinnesotaFarmall said: I presume this is for a fence as I see the wire in the grass. Are you using it for an anchor or have you developed a way to attach wire to it? Fence this was to hold wire up coming out of the creek. Ez twist drill clips wrap the post and wire hold well and are easy to install. 1 Quote Link to comment Share on other sites More sharing options...
