Mic4Jesus Posted June 14 Share Posted June 14 Hello, I am wanting to add an auxiliary valve to a 1486 powered by the power beyond. I know it's an open center system and I'll need an open center valve. I also know that I should be able to feed my valve from the port coming out the front of the end plate on the valve body. My question is it seems that on this tractor the brake lube lines also are fed from that port. So I probably don't want to cap that line off. But if I tee off of that line to feed my valve it would pressurize the brake lube lines when I'm using the aux valve. Any help? Quote Link to comment Share on other sites More sharing options...
HydroTek Posted June 15 Share Posted June 15 On the valve stack end plate, remove the large supercharge line, that runs to the MCV connect the line that feeds your new valve inlet to the fitting on the valve stack connect the return from your new valve to the supercharge line, to complete the circuit This is an easy add on for a secondary valve 1 1 Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted June 15 Share Posted June 15 2 hours ago, HydroTek said: connect the return from your new valve to the supercharge line, to complete the circuit Last time I said that I was admonished because that puts "un-filtered oil" into the MCV. Even though I had documented proof of that exact recommendation having been made dozens of times in the past, with absolutely no concern expressed for putting "un-filtered oil" into the MCV. Quote Link to comment Share on other sites More sharing options...
snoshoe Posted June 15 Share Posted June 15 42 minutes ago, Matt Kirsch said: Last time I said that I was admonished because that puts "un-filtered oil" into the MCV. Even though I had documented proof of that exact recommendation having been made dozens of times in the past, with absolutely no concern expressed for putting "un-filtered oil" into the MCV. I remember that and said nothing. If it makes you feel better it is no more unfiltered than the auxiliary return oil that still returns there. Quote Link to comment Share on other sites More sharing options...
stronger800 Posted June 15 Share Posted June 15 What makes some oil filtered, and some oil unfilter? In my mind, all of the oil is filtered ….because it gets through the filter at some point. Quote Link to comment Share on other sites More sharing options...
HydroTek Posted June 15 Share Posted June 15 Then the return oil from the factory valve stack is "unfiltered" also -- LoL Do the mod and don't over think it. I have done this mod many times for customers -- Also have a couple out there with variable flow to run a hydraulic motor from that same port -- and the controls are inside the cab -- pretty slick setup 1 Quote Link to comment Share on other sites More sharing options...
bitty Posted June 16 Share Posted June 16 here is a thread that I asked for the correct ways to add to my 186 1 Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted June 16 Share Posted June 16 Pretty sure this is an "official" diagram from IH: 4 Quote Link to comment Share on other sites More sharing options...
gafarm49 Posted June 16 Share Posted June 16 19 hours ago, HydroTek said: Then the return oil from the factory valve stack is "unfiltered" also -- LoL Do the mod and don't over think it. I have done this mod many times for customers -- Also have a couple out there with variable flow to run a hydraulic motor from that same port -- and the controls are inside the cab -- pretty slick setup could you run a 8 row air planter with this setup without heating the oil too much? Quote Link to comment Share on other sites More sharing options...
HydroTek Posted June 17 Share Posted June 17 Maybe, ...the mod I done ran a spray pump 15 gallons enough for that planter ? -- just need to watch your temperature Quote Link to comment Share on other sites More sharing options...
gafarm49 Posted June 17 Share Posted June 17 7 hours ago, HydroTek said: Maybe, ...the mod I done ran a spray pump 15 gallons enough for that planter ? -- just need to watch your temperature acccording to the manual the planter fan needs 6-7 gpm so that doesnt leave much for the lift and remotes Quote Link to comment Share on other sites More sharing options...
HydroTek Posted June 17 Share Posted June 17 A push-pull diverter and flow control valve would be the simplest setup to use you could sub in a 2 spool valve if there is a need for an extra remote -- but one spool would be dedicated to the flow control I modded a push-pull diverter and flow control under the cab then ran the control rods thru the floor, near the RH console -- one for the diverter and another for the flow control There is no priority valve on the '86 series with open center -- and connecting the planter fans like this will cause some variation when lifting the planter . The full flow still goes to the lifting operation, and since the return from the valve stack is supplying the fans you would notice some pressure fluctuations -- as long as you do not hit relief when the planter lifts, the fans will still operate -- other wise flow at the valve stack power beyond port stops, while the main relief is open https://www.northerntool.com/products/hydroworks-side-ported-flow-control-valve-sae-12-ports-30-gpm-model-fc163n11-69826? https://www.northerntool.com/products/buyers-products-nptf-2-pos-selector-valve-gpm-10-working-port-1-2-in-max-psi-3000-model-hsv050-4901703 Quote Link to comment Share on other sites More sharing options...
gafarm49 Posted June 17 Share Posted June 17 6 hours ago, HydroTek said: A push-pull diverter and flow control valve would be the simplest setup to use you could sub in a 2 spool valve if there is a need for an extra remote -- but one spool would be dedicated to the flow control I modded a push-pull diverter and flow control under the cab then ran the control rods thru the floor, near the RH console -- one for the diverter and another for the flow control There is no priority valve on the '86 series with open center -- and connecting the planter fans like this will cause some variation when lifting the planter . The full flow still goes to the lifting operation, and since the return from the valve stack is supplying the fans you would notice some pressure fluctuations -- as long as you do not hit relief when the planter lifts, the fans will still operate -- other wise flow at the valve stack power beyond port stops, while the main relief is open https://www.northerntool.com/products/hydroworks-side-ported-flow-control-valve-sae-12-ports-30-gpm-model-fc163n11-69826? https://www.northerntool.com/products/buyers-products-nptf-2-pos-selector-valve-gpm-10-working-port-1-2-in-max-psi-3000-model-hsv050-4901703 thanks alot!!! I may try this this winter and may be bothering you alittle if thats ok 1 Quote Link to comment Share on other sites More sharing options...
gafarm49 Posted July 5 Share Posted July 5 On 6/17/2023 at 8:47 AM, HydroTek said: A push-pull diverter and flow control valve would be the simplest setup to use you could sub in a 2 spool valve if there is a need for an extra remote -- but one spool would be dedicated to the flow control I modded a push-pull diverter and flow control under the cab then ran the control rods thru the floor, near the RH console -- one for the diverter and another for the flow control There is no priority valve on the '86 series with open center -- and connecting the planter fans like this will cause some variation when lifting the planter . The full flow still goes to the lifting operation, and since the return from the valve stack is supplying the fans you would notice some pressure fluctuations -- as long as you do not hit relief when the planter lifts, the fans will still operate -- other wise flow at the valve stack power beyond port stops, while the main relief is open https://www.northerntool.com/products/hydroworks-side-ported-flow-control-valve-sae-12-ports-30-gpm-model-fc163n11-69826? https://www.northerntool.com/products/buyers-products-nptf-2-pos-selector-valve-gpm-10-working-port-1-2-in-max-psi-3000-model-hsv050-4901703 So with this setup where would be a good place to install a temp sending unit for the hyd fluid and what temp would be too high? Would it help to run more fluid? I already run 5 gal over. So much of my peanut equipment has hyd motors it would be neat if I could use these tractors more. Even thought about a cooler added somewhere Quote Link to comment Share on other sites More sharing options...
acem Posted July 5 Share Posted July 5 If you use the oil cooler that comes on the cyclo planter it should keep the oil cool. But a temp gauge would be good. Quote Link to comment Share on other sites More sharing options...
