TD8E
Buddy has a TD8E. It starts and runs but will not run more than half throttle. He had injectors rebuilt and problem still exists. Moving the throttle past cold start it immediately does to half throttle.While it's running I can move the lever on the injection pump and it will not increase or decrease the rpms. Deceleration pedal does nothing when you try to idle down. Anyone have any ideas?
move to construction page.
fuel restriction either/both in /out...............cummins 4bt?
dedicate fuel tank strapped to the roof........
check pressure 14 + /replace the $40 lift pump.
but description may be 239?  advance broke         /proper return HOSE ?
then ck danny for pump suggestions
An 8 E should have an IH D239
