Red Dirt 806 Posted May 25 Share Posted May 25 I have a good 806 LP with a stacked bearing. I have a good running 966 with major transmission and rear end issues. Question is can I put the 2 together at the bell housing and use the 966 sheet metal? Quote Link to comment Share on other sites More sharing options...
stronger800 Posted May 26 Share Posted May 26 Think of the front radiator casting. That’s what comes to my mind first anyway. They are not compatible with the other style hoods you could swap out the transmissions and rear end though. Put the 806 center and rear into the 966. Use the 966’s fuel tank and steering column. And speed and range covers off the 966. Quote Link to comment Share on other sites More sharing options...
snoshoe Posted May 26 Share Posted May 26 7 hours ago, stronger800 said: Think of the front radiator casting. That’s what comes to my mind first anyway. They are not compatible with the other style hoods you could swap out the transmissions and rear end though. Put the 806 center and rear into the 966. Use the 966’s fuel tank and steering column. And speed and range covers off the 966. He has this posted in projects too. I told him no. Two inch difference in bell housing widths . Pretty sure bolt pattern doesn't match either. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted May 26 Share Posted May 26 50 minutes ago, snoshoe said: Pretty sure bolt pattern doesn't match either. Bolt pattern does match. I have an 86 series rear engine plate in the 756. Sticks out but it bolts right up. Quote Link to comment Share on other sites More sharing options...
snoshoe Posted May 26 Share Posted May 26 1 hour ago, Matt Kirsch said: Bolt pattern does match. I have an 86 series rear engine plate in the 756. Sticks out but it bolts right up. Then I am corrected. Thanks. Quote Link to comment Share on other sites More sharing options...
Gearclash Posted May 26 Share Posted May 26 Fix them both. Win Win Win. 1 Quote Link to comment Share on other sites More sharing options...
Dan Robinson Posted May 26 Share Posted May 26 Will bolt right up. You'll have to use the 966 fuel tank and supports. Quote Link to comment Share on other sites More sharing options...
RAH Posted May 26 Share Posted May 26 Yes will work fine as stated. Will make you a nice project. Quote Link to comment Share on other sites More sharing options...
stronger800 Posted May 26 Share Posted May 26 966 fuel tank, supports and column, How about the radiator support? And range cover. I felt the way I suggested was easiest. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted May 27 Share Posted May 27 I was assuming that the end result would look like a 966, so the radiator and radiator support would come along with the 966 front half. If the desired result is to have it look like an 806, then it's a bit more work. Turns out from the other tread that you don't have to change the column at all. All the 66 series stuff allegedly bolts on to the 806 column. So no need to change the range cover if you don't mind keeping the 806 shifting. 1 Quote Link to comment Share on other sites More sharing options...
acem Posted May 27 Share Posted May 27 I've seen a 1456.with a DT414 so it can be done. Quote Link to comment Share on other sites More sharing options...
