brian falcone Posted May 9 Share Posted May 9 Quick question as I can't find part numbers. Does the drott td6 62 series use the same final drive housing that the early mid 50s td6 used ? Quote Link to comment Share on other sites More sharing options...
mike newman Posted May 9 Share Posted May 9 ....the ''9'' series finals are same for bolt pattern's ...some variants in the ''outer rib'' castings as the HP increased (81series ).... ...does not answer your question....as such... but ...one would imagine the same 'pattern '' would apply Mike Quote Link to comment Share on other sites More sharing options...
louie figone Posted May 9 Share Posted May 9 TD6 part number: 8503 DBX, TD6-61 8503 DCX, TD6-62 8503 DDX, the TD6 carrier uses a 1 inch plug, the 61 and 62 series use a 1-1/4 inch plug. They are the same aside from minor differences. These part numbers are for the carrier with the wide thread, the equipment combination (loader/sideboom) use a different carrier, 54 inch gauge verses 50 inch gauge. The sprocket drive pinion bearing is the same for the 61 and 62 series, TD6 has a different pinion bearing part number, I can't imagine the bearing pocket would not be the same. I can scan the parts book pages that covers the carrier if you need. 2 Quote Link to comment Share on other sites More sharing options...
