td9bcf180 Posted May 18 Author Share Posted May 18 Thanks Mark. 11 quarts engine oil. Have to drain some out this weekend. BTW- the air breather and connecting "pipe" are not plugged or blocked. If I adjust the oil level accordingly, and it still blows oil out the stick, then I must have a broken ring (s) or bad piston. (???) Worst case scenario but will try oil level first and hope that solves the problem. 1 Quote Link to comment Share on other sites More sharing options...
mmi Posted June 4 Share Posted June 4 ? ,those engines (should) have the low sleeve Below oil as you removed,just for this running purpose,removal./check level .but do pulse with pressure difference.? IF 2-4 qt over,rod slap may,be resonating the oil up the tube at correct level/stick ,I would thread the replacement on and move up to the filler for pressure inspection.? <10p then at #12 PCV (messicks /400d/ 12-242-(12) )........0.../.mud wasp/sludge in head from there if rings etc should be out valve train breather 1 Quote Link to comment Share on other sites More sharing options...
