Hey finney
mader656
@Finney @AKwelder and the rest of you welders im struggling with getting 2 7/8 copeed to 4 inch pipe i reground my cutting gauge but hoping for other ideas to speed up fit as ive got over 1000 to do.
I have used a cutoff wheel on a grinder, but it was on handrails. Same size posts, though. Not sure if it will work for you on this job.
 I just cut an angle off top and bottom.
That is some serious fence.  What are they keeping in?
Keeping maintenance to zero. Couple of horses.
How are you cutting it now? I have had good luck using a hole saw, but it is slow and wouldn’t hold up long term.  Are you using acetylene or plasma?
Can you free hand plasma cut those?
I learned this method from one of the Mennonite kids when they built out barn . He used a demo saw to cut the pipe. Holds up pretty well but not 100% but 6010 first pass then 7018 and then it's good to go
Plasma. Roughly 2400 copes to do
Ive done similar with the portaband
Mader,
 When using 2-7/8" cross pieces into 4" pipe I cut holes in the 4" and insert the 2-7/8" into the 4". Alot faster, I use a circle cutter on a 180* torch head.
I haven’t done much pipe fence.  I would try Finney’s method. It would be more forgiving and you can dress up the hole with a stone if you need to.
 I have seen the chop sawing the ends like Bitty shows and it works after you get it dialed in.
If we are cutting saddles for piping we normally make a steel template that slips over the pipe, which is what it sounds like you doing. I have an App that calculates my ordinate lines for saddles when we are doing one off versions
I have seen a similar method to the one you describe only using square stock as the guide.
I usually do a flat pattern layout on paper. Using AutoCAD is easier but have done it in the field also with basic tools. For numerous cuts I transfer to a small piece of pipe. Pipe fitters handbooks have the process to make the layout. Easy once you’ve done a couple and works perfectly every time for all sizes and angles of joints
2 hours ago, Finney said:
Mader,
Im afraid this  4 inch is nearly  .375 wall it cuts extremely slowly and very little room for error.
Ive got my modified cut gauge, im going to pickup a few other tools to help speed it up the process and my first employee starts tomorrow so we will see how it goes.
A lot of the 4" we use is .375 wall or thicker. I can still cut 4 holes faster than saddling 4 ends of pipe. plus you can cut the cross pipe 1-1/2' longer than the  actual measurement between the post so you dont have to be as accurate with the cuts as you would if saddling the pipe. I cant stand a coped/saddled pipe someone has cut a 1/4' short. Plus I never had the post that were exactly plumb, the top or bottom will be shorter if cop/saddling where as the insert method it does not matter. It usaually takes me a couple of holes to get the circle cutter adjusted where I want then its turn and burn.
  • Like 6
Our boys are pest fencing the ranch using 6 foot woven mesh with 1 foot a bottom lap, which needs substantial end assemblies.  They have an hydraulic cylinder set up run by the skid steer that flattens the ends of the horizontals.  Makes for easier cutting and welding.
Crushed ends look ok in the back 40 not the front yard...also a strength issue.
Any links back to that strength issue as I must have missed it?  TIA
The squasher does double duty as the wood splitter here
Im not 100%  certian on links but crushing the ends causes the tube to be deformed and  bend easier. Im sure it will hold the us farmer tight fence just fine. But good tight tall high tensile woven might be a issue.
This type of fence and driven steel posts don't happen in our part of the country or at least that I know of.  Everything here is treated wood posts.  Why is that?  I'm guessing moist climate rots of all but the thickets wall pipe.  What kind of life expectancy on this fence?
I assumed that was drill pipe, rumor has it it is cheap and plentiful in the right place. I want to figure out where to get it and make a road trip with a trailer.
