PTO control valve
François02
New leak today, every time I start the engine I discover something :D
It comes from the PTO control valve
On the parts catalog there is 2 seals but I'm not sure of what is the part #31 and if I need it
Of course, here the #35 is not available...
The 3pts linkage is here only to cover the hole, I have a new one perfectly painted who will be installed when I will have set the draft control (there is a screw inside the carrier ;) )
53 minutes ago, Red Tech said:
The oring, number 35, is easily available.  The new number is 89626929, which replaces 237-6014.
The seal number is 381477R91.
Reuse part #31, it is just a spacer.
the oring ref is #297459R1
not available but indeed replaced by #89626929 and this ref is the same as #70921886
  • 4 weeks later...
Spool does not come out the top. Yes you have to remove #45. Lift spool and find small hole in stem. Insert Allen wrench in hole to keep from turning and unscrew #45. If no set screw or jam nut. It may be loctited and need a little heat.
1 hour ago, François02 said:
that is the problem: I can not remove the whole axle
I have to remove the square part #45
Yes, remove that part first
may need to need to heat the square nut a little if it has lock-tite on the threads -- check first in case someone has drilled and installed a set screw in the square nut
