hunting carriage bolts
We got drafted to work on the soil conservation service's notill drill,it needs all new bolts on the unit attachment brackets. I ordered new one's from the dealer and in my opinion they are too short,the shoulder is not long enough to engage the main wear point. So i have searched all over the web looking for a hardened 1/2" X 8" carriage bolt with atleast a 6 1/2" shoulder with no luck, any suggestions on where to find them.
Isn't there nylon bushings in there for the main wear point with the shoulder just used to stop rotation ?
5 1/2" metal bushings that show very little wear. the factory bolts are just a little short in my opinion, allowing the threads to wear in the hole,slightly longer bolts with a lock nut would take 90% of the slop out IMHO.
I found these guys when I was looking for grade 8 but it turned out my local guy had them all along:
https://www.boltdepot.com/Carriage_bolts_Grade_8_steel_plain_finish.aspx
https://www.boltdepot.com/Carriage_bolts_and_Plow_bolts.aspx
Sorry, looks like they only go to 6". Might be worth calling.
Like to help out if I can
https://www.zieglerbolt.com/carriage-bolts-2
they will make them to your spec if needed
23 hours ago, from H to 80 said:
i will check these all out ,thanks guys.
They show what i need but they are out of stock.
Bummer!
Suggest calling them find out eta. Just my thoughts.
They made the fine square wheel 1/2 -20 bolts for me I could not find anywhere .
