Help with 544 brake shims
I am going through my farmall 544s brakes and I notice it is shimmed, both sides didn't match for how many shims it has, could somone please explain how I should shim it? Each side has 2 spots that need swimming, inside and outside.16808126331791202590816862680352.thumb.jpg.dde0dc1e999417af924cc7cbb9ba77c4.jpg
Inside shims are for differential carrier bearings and ring and pinion lash. Do not change. Outer shims. Back off adjusters and remove as many shims as you can without causing brakes to drag. Then use adjusters to even pedals.
The inside shims just affect how far out the housing is so it adjust the inside disc brakes, there is no bearing on that part just an o ring and seal
The inside shims do not adjust the brakes but you did shift my brain out of neutral. They do shim a bearing. Right now I can not shake the fog. It is either as I said or just bull  pinion bearing.  Anyway I advise not to change.
22 minutes ago, snoshoe said:
O k I've got it now. If you were leaking oil there. You probably should go through the procedure to check the play in the shaft. I could recite the procedure but can't quote any of the specs.
I'm not by the tractor now but I'm sure your right what your saying .
Shims behind the "pinion cage" (the part still in tractor in your picture) set Differential bearing end play.
The inner shims you are talking about (behind the brake housing) set the bull pinion bearing end play.  Don't change to change brakes
The outer shims set the brake clearance.
