5288 cigarette and dome light power
IH686neuss
Does anyone know where the power for the cigaretter lighter and dome light come from i found them on a wiring diagram but didjt not see where they were fused or pulled power from
With roof off look in and on the right side there should be green wire that has a red wire fastened to it . the red wire goes to the dome light making it hot all the time. The green wire goes in to a harness and goes down the right side pillar and curles under the front foot plate  , there is a place where  it is plugged in to the bigger harness. from the big harness it goes in to the fuse block .the fuse you will check is the third one down on the left side .  hope this helps       Jim
