756 - Clutch settings + TA dump valve
François02
Wait a minute, didn't some of these have a drive in seal, and they went to an o-ring with the newer stuff.
Let me do some looking?
An o-ring won't work in the adapter he is showing as there is no groove to hold the o-ring.
No wonder it leaks?
Update:
I went back to the 806 parts manual on Case/IH and that shows an o-ring on the TA lever spool valve and TA dump valve.
I can't tell if this was a change over from the seal setup.
I remember the vice was a great way to press that seal in.
But I may be thinking of the seal on the PTO engagement shaft?
Now I don't know, other than what he has won't work with an o-ring.
I think I have found what happened...
The O ring in the TA valve and in the dump valve are very similar and my dealer exchanged them
I have changed everything and it seems it works now, without a leak (need to be confirm)
I just have a small leak on the steering valve, a line who goes to the steering cylinder. To tighten it, I need to dismantle the battery and the starter motor :(
7 hours ago, stronger800 said:
I think I have a ground thin wrench, maybe bent a little, for that job
it is very difficult to made one wrench for this job, and it will be faster dismantling the starter motor and the battery. I hope tighten a bit more will be enough...
  • 1 month later...
