Zebned Posted March 29 Share Posted March 29 Looking to find out what an 8 bottom 700 IH on land plow might weigh for shipping purposes. Can't find any literature about the weight on the internet or at the local dealer and the plow isn't close enough to a scale to weigh it. So if anyone has any old literature that might have an approximate shipping weight, that would be great! But, I can't think the machine weighs over 7,500 pounds. Quote Link to comment Share on other sites More sharing options...
1480x3 Posted March 29 Share Posted March 29 I assume it is trailing ? Never saw the semi mount in as an 8 btm. Wouldn't think either would be over 7500 even in auto reset. But bet the trailing would be the heavier one though. Quote Link to comment Share on other sites More sharing options...
Zebned Posted March 29 Author Share Posted March 29 Yes, it is a trailing plow with autoreset. Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted March 29 Share Posted March 29 5000 #'s give or take a hundred or so Quote Link to comment Share on other sites More sharing options...
E160BHM Posted March 30 Share Posted March 30 January 1984 price book shows 800 trailing plow with on-land hitch, 9 bottom with automatic beams at 7725 lb. No 8 bottom is listed. Quote Link to comment Share on other sites More sharing options...
EASY BOB Posted March 30 Share Posted March 30 I have had quite a few 700 high clear pull type automatic reset plows , bought and sold. And hauled. Your 8 bottom should be right around 7500 lbs. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted March 30 Share Posted March 30 7500 should give you plenty of wiggle room on the weight. One 8-bottom shouldn't weigh too much more than two 4-bottoms, and I can lift a 4-bottom easily with the 756 and 2350 loader. I've had buckets of wet snow that squatted the front tires and lifted the rear of the tractor more than that plow did. Quote Link to comment Share on other sites More sharing options...
bitty Posted March 31 Share Posted March 31 22 hours ago, E160BHM said: January 1984 price book shows 800 trailing plow with on-land hitch, 9 bottom with automatic beams at 7725 lb. No 8 bottom is listed. Correct the 800 was 9 bottom on the smallest one available but we have an 8 bottom as previous owner cut one off to pull it with a JD..... 1 1 Quote Link to comment Share on other sites More sharing options...
Zebned Posted April 3 Author Share Posted April 3 Thanks to everyone for your input! That helps in finding a trucker willing to haul it! Quote Link to comment Share on other sites More sharing options...
