782DT (1572 turbo) drive shaft
Mr. Plow
Had dead battery on the diesel over winter, needed to move it, so swapped in a new battery...fired right up and then wouldn't move.   Cold weather start disconnect clutch shot craps.  Odd, drove fine going in shed when I parked it, now clutch is shot.   Must have had too much of a work out on the chisel last fall!!!!!
New parts are on the way to delete clutch and run it direct.
Was planning on rebuilding its drive line this coming fall....in new shop.  Looks like that project got bumped up to BEFORE  new shop.....
Nope.....just one more thing.  Once parts are here it should be a Saturday project.
20hp gas has been TRYING to get the driveway in between rain drops....at least it loosened up to help dry it down.....
Culvert pipes are waiting for install...20230320_173001.thumb.jpg.b0ad67f1fda55143121124a7628b4196.jpg
  • 2 months later...
Got to claim a quick fix on diesel.  Sheared std 1/4" roll pin in disconnect clutch.   Replaced it with a spirol and buttoned it back up.   Will get full driveline rebuild this winter when I have more time.
