media for sandblasting
ny bill o
I bought a cabinet sandblaster years ago, never used it. I have a 1960s metal PowerTrac pedal tractor taken apart to clean the rust off of. Not thick rust, just want to get it ready to paint. What would you recommend to use?
Sodium bicarbonate is supposed to work although it would be pretty fine
this what I'm working with. The other side is total rust.
I’m not a sand blaster but I had some parts done last year. The shop used glass, and it sort of imbedded itself into the metal. My metal was not rusty, but it had three layers of paint on it and I wanted it gone.  I had to do a bit of sanding to get the glass “off” the steel.   I was going to ask if they could use soda or something fine, as a finishing pass, if I do it again.   I used 320 paper on a jitterbug.
I use glass beads in a cabinet and black beauty (coal slag) in a pressure blaster outside.
Put some beads in that cabinet and you'll find you'll be using it often on all sorts of things.
I think I have the twin to that in a shed. Or at least something very close.
On 3/10/2023 at 9:20 PM, Farmall Doctor said:
How long do the glass beads last? I started with crushed glass, and I got rid of it… went to Black Beauty.
I get good life out of them. As they eventually break up they go out as dust to the collector. I just replenish to keep the siphon buried and to allow for what collects on the edges of the screen floor and parts that I seem to leave in forever. Clean out and sieve when I get clogs and replace the plastic view protector at the same time.
I use one of those pre-collectors that fit on a 5 gallon bucket so I don't have to change the bag as often on the old shop vacuum that serves as a dust collector.
One of my friends was using black beauty and found glass beads worked way better in his cabinet. Black beauty is really disposable stuff.
