square head bolts on a 350 rim wedge?
pt756
Hello, taking the rim and wheel off the 350 to fix the axle leak, rim is rusted thru anyway, there are those 8 square head fine thread bolts, that hold the wedges to the rim, well 6 came loose , 2 of them broke off, they were rusted half off, i am assuming the others arent that good of shape, where do you get replacements? thank you
A&I had ones that fit the 1066 ETC. Not sure if they'd have these also, you will be needing 5/8" fine thread by 2 1/2"?
I bought a set for one of my 560's from CIH a couple years ago. They wernt to bad a price
Last summer I was looking for a set of these for 560. Bolts were easy enough to find, the nuts were the problem then. Forum member here hooked me up with an eBay ad. Got nuts and bolts for a good price and they actually shipped from a CIH dealer in Michigan.
