nate Posted February 17 Share Posted February 17 Anybody have a pic of wiring diagram for 1026? We are trying to fix some wiring and don’t have a book yet. Thanks Quote Link to comment Share on other sites More sharing options...
Farmall1066 Posted February 18 Share Posted February 18 I did a search, and I came across some old posts of others needing a diagram for a 1026, everyone said use the 1256 diagram, if you have one. Quote Link to comment Share on other sites More sharing options...
tractorholic Posted February 18 Share Posted February 18 If you have a 706 owners manual that has a pretty good diagram in it. I think it’s the same as a 1256 wiring wise Quote Link to comment Share on other sites More sharing options...
nate Posted February 18 Author Share Posted February 18 We have a few different 56 manuals. We are going off them. Not sure about sensor on foot n inch pedal or pressure sensor on hydro? Quote Link to comment Share on other sites More sharing options...
snoshoe Posted February 18 Share Posted February 18 57 minutes ago, nate said: We have a few different 56 manuals. We are going off them. Not sure about sensor on foot n inch pedal or pressure sensor on hydro? The foot and inch is the pressure (actually flow sensor) the one on the hydro is temp. They are parallel grounds for the tell light. Ground either one and the light lights. As I recall wire comes from tell light to foot and inch. Shares terminal with feed to temp switch. Temp switch grounds through casting. Other terminal on foot and inch is ground. Don't remember exactly where it grounded. Not that it matters much. Quote Link to comment Share on other sites More sharing options...
SDman Posted February 19 Share Posted February 19 nate, this is a schematic for an early 9/1066 Hydro with an alternator with an external voltage regulator. Should be similar to a 1026 in most respects. I cannot seem to find a schematic that is specific to 8/1026 Hydro. Hope this helps anyway. Quote Link to comment Share on other sites More sharing options...
nate Posted February 19 Author Share Posted February 19 Thank you for everyone’s help. The diagram you added SDMan answers our questions. Just trying to get 50 year old wiring fixed to work like it should. 1 Quote Link to comment Share on other sites More sharing options...
