Sliding 5488 back together
acem
Ace.   We’ve only done one 50 series so can’t give a whole lot of advice.  I would agree that 1/4” is too much difference.  Be careful, the master clutch has the teflon ring that has to survive so it works correctly.
Ace i've never had a 50 series split that far back so i'm no help but give mike a call he's good at explaining things over the phone maybe with you standing there looking at it with him on the phone yall can figure it out
I thought 1/4 inch was close enough but maybe not.
If Mike doesn't respond by the time my friend gets back from Florida I'll give him a call. I bought the parts from Mike and he's been very helpful whenever I call.
Thx-Ace
I realize I am preaching to the choir here!
When working with blind hole alignment issues we need to use as many close fitting alignment pins as you can get at to remove. Custom made (removable) alignment pins are the best you can do.  We have used various length close fitting bolts as dowels by removing the heads and slotting them for screwdriver removal .
Major issues are keeping everything square aligned synced and plumb.
We have a little (coffing) brand name 1 1/2 T ratchet chain any angle come-a-long it has the ability to move a very small distance  to nudge something along.
When it refuses to go together completely re investigation and  finesse with light pressure is always the best response.
Get it squared and plumb, then reach through the hole where the filter goes and turn the clutch and speed to range shaft.  Not sure what binds, took 3 tries on mine and then it popped right together
It just an alignment problem.  Lock the range in 2 gears this will keep the master from turning.  Ive had to put a pliers on the output shaft to get splines lined up on master.  The pump,pto driveshaft will line up easy as its tapered and will turn.  This is why i always split engine off then the speed trans.  Its easier to work with and turnnthings.  The engine makes it difficult to turn trans shafts fast to align splines
I don't have any sound advise for you but hopefully I have a little better luck. I split my 54 today for the master clutch.   I'm ready to put the clutch back in and roll it together so we will see how it goes.
Did you put new Teflon seals on the master clutch?  The ones on mine look real good yet so I'm debating leaving them.
I suggest you slip one off and measure thickness compared to new. May help the decision.
I'm curious how you dealt with the lube spray line? I don't see the necessary covers removed in order to disconnect the line.
Absolutely put the seals and teflons in.  Teflons are known for breaking the hooks off
19 minutes ago, tractorholic said:
It would be impossible for me to not put new Teflon’s in. You won’t be able to do it any easier than when you are right there.
You could also say that about the synchro disks a little further back and the speed forward.   The fact is the cost of parts is crazy.   Personal preference I guess
I guess I shouldn’t have said that but When we’ve got something apart I like to hope I that it’s the last time We will be in there for a long time. A few dollars extra while in there makes sense to me. Cutting corners usually bites me in the rear.
I guess I have no idea what your talking about.
I'll go ahead and put the Teflons on - I was just hoping to save the $240
While she apart we are replacing the master clutch, high/low clutches, synchronizers, etc.
The axle bearings have a little play. We plan to replace them next.  I'm thinking really hard about the brakes While I'm there.
Parts have gone up but I don't expect them to go down...
Thx-Ace
There's a lube spray pipe that runs along the top left side in the speed transmission, sprays on speed gears and supplies additional lube oil to other areas of the transmission. The only way(that I know of) to split the tractor where you did is to either cut the lube line in half with a tubing cutter or disconnect the lube line in the range transmission. I see the side fuel tank is still installed, so the side plate to access the lube line hasn't been removed and the side plate on the speed transmission is still installed. This is where one would access the lube line to cut in half. Just curious more than anything, maybe I can learn a new trick for the next time I do it.
Thx-Ace
I would sure think about changing the o rings in the brakes while the axle is off. Mine were kind of flat and before we changed them the first time you used the brakes after you started the tractor you didn’t have them for a few seconds. Now they are right there every time you use them.
The attaches on front and back of speed trans.  No need to remove it to splits like they did.  It doesnt attach to anyof the range
Yeah, I had wires crossed on this deal. I was thinking about when removing front plate when only splitting at engine. Thanks
  • 3 weeks later...
Got her slid back together today!
Took the pump drive off. The pto shaft wasn't quite right. When we got it good it slid right together.
Thx-Ace
