iowaboy1965 Posted April 10, 2024 Posted April 10, 2024 21 hours ago, DT Fan said: Got the first 16.9 on the 400 today, hadn't ever mounted a double bevel rim before. Wasn't too bad, think I got the runout down to less than 1/4". Decided to head to work early to pick up some onions and potato seed. Other tire will have to wait until tomorrow. Swap that to the other side and you could run that thing at Knoxville with that stagger! 😁 2 Quote
DT Fan Posted April 10, 2024 Author Posted April 10, 2024 Got the other 16.9 mounted today, apparently, I pinched the tube, again. At least this is a different tire. Ran out of time so it will have to be looked at tomorrow. Took a picture of the new tire next to the old one. 10 Quote
lorenzo Posted April 11, 2024 Posted April 11, 2024 My cousin is exercising the Offset Miller today. 7 Quote
Alan Dinan Posted April 11, 2024 Posted April 11, 2024 36 minutes ago, nepoweshiekfarmalls said: Broke again. 3rd time lucky? The old saying is “Third time’s a charm!” Quote
48 farmall M Posted April 11, 2024 Posted April 11, 2024 Got the dual patched for 7110. Gonna get going on spring tillage tomorrow 4 Quote
iowaboy1965 Posted April 11, 2024 Posted April 11, 2024 Ground some chicken feed last nite with the 560. Forgot pics. 8 Quote
IHandJDman Posted April 11, 2024 Posted April 11, 2024 Fed the cows through the slop with the 1456. 4 Quote
int 504 Posted April 11, 2024 Posted April 11, 2024 12 hours ago, nepoweshiekfarmalls said: Broke again. 3rd time lucky? If it breaks again maybe add a piece on top and pieces on the sides after welding the break. 1 Quote
Alan Dinan Posted April 11, 2024 Posted April 11, 2024 28 minutes ago, int 504 said: If it breaks again maybe add a piece on top and pieces on the sides after welding the break. Or perhaps another u bolt and bracket out at the end of the frame 3 Quote
nepoweshiekfarmalls Posted April 11, 2024 Posted April 11, 2024 2 hours ago, int 504 said: If it breaks again maybe add a piece on top and pieces on the sides after welding the break. I had a support piece welded to the rear. Dad wound an electric fence post into the spools and broke it! Quote
SMDFarmboy24 Posted April 12, 2024 Posted April 12, 2024 I unloaded a field cultivator with my little 424. Just enough to get it off of the trailer. 6 Quote
hardtail Posted April 12, 2024 Posted April 12, 2024 8 hours ago, nepoweshiekfarmalls said: I had a support piece welded to the rear. Dad wound an electric fence post into the spools and broke it! I always think back to the patience my parents gave me when I was younger BUT there is a reversal of the guard when they do stuff that is sometimes beyond belief, leaves room for payback on the balance scales Quote
Cool1566 Posted April 12, 2024 Posted April 12, 2024 23 hours ago, nepoweshiekfarmalls said: Broke again. 3rd time lucky? My guess is the disc is rejecting the green bolt. Trying to lose it anyway it can. 1 Quote
billonthefarm Posted April 12, 2024 Posted April 12, 2024 Still spreading dry. Wind came up so I switched to field cultivator then I did a little harrowgator work. 11 Quote
48 farmall M Posted April 12, 2024 Posted April 12, 2024 got the planter out and sheds ready for summer 3 Quote
MT Matt Posted April 12, 2024 Posted April 12, 2024 Finished disking/harrowing the field I was working on two days ago and got the grain drill moved/prepped to go. Hooked up and dropping it in. Stopped just in time to reload! Planted 10 acres of oats and 8 acres of oats/grass mix. Plus a little strip of alfalfa. The 10 will be alfalfa next year so needed to square things up. The field is 40 acres all together. I’ve planted the other part back to grass last year. Need to finish harrowing that to knock down the mole mounds. Finished the day by rolling the 8 acres with the A. One step forward, and one broken packer wheel back! As you can see, the wheel centers are pretty much wore past use but it got the job done. 9 Quote
MacAR Posted April 12, 2024 Posted April 12, 2024 13 minutes ago, MT Matt said: Finished disking/harrowing the field I was working on two days ago and got the grain drill moved/prepped to go. Hooked up and dropping it in. Stopped just in time to reload! Planted 10 acres of oats and 8 acres of oats/grass mix. Plus a little strip of alfalfa. The 10 will be alfalfa next year so needed to square things up. The field is 40 acres all together. I’ve planted the other part back to grass last year. Need to finish harrowing that to knock down the mole mounds. Finished the day by rolling the 8 acres with the A. One step forward, and one broken packer wheel back! As you can see, the wheel centers are pretty much wore past use but it got the job done. That looks good Matt! So after you drill your oats, you follow them with a packer. Would a spike harrow have the same effect? Mac 1 1 Quote
48 farmall M Posted April 12, 2024 Posted April 12, 2024 37 minutes ago, MacAR said: That looks good Matt! So after you drill your oats, you follow them with a packer. Would a spike harrow have the same effect? Mac That is what we usually do. works nice 2 1 Quote
DT Fan Posted April 12, 2024 Author Posted April 12, 2024 Finished the 16.9 tire project on the 400, I hope! 4 1 Quote
MT Matt Posted April 12, 2024 Posted April 12, 2024 4 hours ago, MacAR said: That looks good Matt! So after you drill your oats, you follow them with a packer. Would a spike harrow have the same effect? Mac Thanks! I rolled the area I planted grass over the oats. The grass seed box on the front of the drill just dribbles in front of the disks. The disks cut furrows for the grain out of the main box. So the grass seed is in theory on top of the soil. I do mix some grass seed in the grain box because the grass seeder won’t put down the desired amount even when opened completely. About 2 lbs short according to the chart. Seems to work good to roll it afterwards. When I plant just oats, there are some individual drag chains with loops behind the disk openers. I also hook a couple chains slacked across the drill sideways so they drag the furrows closed. I have pretty loose sandy soil out here so there is plenty of soil on top of the oats with this method. The oats doesn’t seem to be too picky, packed or not. Always comes up. And saves another pass over the field to harrow it in. Gary Yeager (Old Binder Guy) drags a wire fence panel behind his grain drill. I had good timing with planting. This morning at 6 am a good sized rain cell rolled over the field and wet it down. Perfect! 2 1 Quote
MT Matt Posted April 12, 2024 Posted April 12, 2024 24 minutes ago, DT Fan said: Finished the 16.9 tire project on the 400, I hope! So what was the reason for going to the taller size? My 400 has 14.9s like yours did. I’ve heard that size is hard to find but haven’t looked either. I like the increased footprint and I’ll bet it scoots down the road! Quote
DT Fan Posted April 12, 2024 Author Posted April 12, 2024 1 hour ago, MT Matt said: So what was the reason for going to the taller size? My 400 has 14.9s like yours did. I’ve heard that size is hard to find but haven’t looked either. I like the increased footprint and I’ll bet it scoots down the road! Mostly just that I like bigger tires. Eventually they will be back on the 450 and the 14.9's will be on here. The 16.9's just exude cool! Kind of wish I would have just bought another pair of them. 3 Quote
