What did you do with your Red tractor today?
DT Fan
Nice Dale!!
I had all four of mine running.
856 went first, it was a little reluctant but not bad.
756 was next, started right up.
1066 was third, probably spun over about twice and was running. Really love that!
826 was last and the most work by far. Took a shot of nose candy and a 200 amp booster. Purrs like a kitten once running though.
Probably would have started the H if it were here just so they all got ran.
When Dad got me involved in this game I looked for a 210 or 220 Allis for quite awhile. Chased a friend of mine's 220 at auction pretty hard once. Second place bidder. It was about 60 degrees that morning and they still had to give it a shot of either. That got me thinking maybe I ought to find a Red one.
11 minutes ago, DT Fan said:
Nice Dale!!
That 1486 or our 1586 has run most days in this year. A couple of the real cold days we didn’t move. We fed the neighbors cows extra not to run those days. They have only been plugged in a couple times this year. But here in Jan feb it has been more mild.
To elaborate a bit why I started them today. Talking to Gene Putz at the toy show yesterday the 826 came up. The flexplate being broken has been discussed as a possible reason for it not moving. He asked me if the pto works? I said I think so but don't remember for sure. Well, it seams to work just fine along with the lift arms steering and brakes. Going to have to dig a little deeper I guess.
It was a really nice day here and just wanted to be outside. Ground is pretty sloppy so I didn't drive anything. Have some loader work to do with the 6080 but it will keep, a long time if it has to.
Used the 756 to pull the 4 wheeler out that I got stuck with a trailer load of behind it. Started the 806 to let it run some.
trailer load of wood
I used my 13,000 hour all original 504 utility( even though TP says that I’m a liar) to pull a dead ford out of the shop due to lack of parts, and pushed a non running Ferguson into its place.
  • Like 7
On 2/19/2023 at 3:58 PM, DT Fan said:
Nice Dale!!
Buddy bought a 7030 and I think owned it for 2 days, his uncle was a big Allis supporter and mentioned he has a generator and plugs them in while he is greasing and checking things over, went back the next day and traded or deal money put towards new IH drills, was way to warm in the season to be buying and using generators to convince your horse to run for his program
Put the 806 on the disc and done the little lot of sod that I plowed last fall so the lady could walk around and look for arrowheads. I really need to start taking pics and learn how to put on here.
It was sunny and 70 yesterday, wife and I got out and split some wood in the morning, had the Cub pulling the splitter around and hauling off the chip pile afterwards.
In the forenoon I hooked the 300 up to the disk and disked the corn stalks I didn't get plowed under last fall:
I didn't think it quite dry enough to plow, but after a couple passes in the dust I decided I'd go ahead and plow it down:
The ground broke very well, and I was finished with all my corn ground a little after 6 yesterday evening. That's pretty well it, I guess.
Mac
  • Like 10
I pushed a Farmall 130 into my shop for an engine rebuild on the weekend.
 A few years ago I made this rig from part of a 3pth blade I got at an auction for 10 bucks. Had I known how handy it is I would have made some improvements to it but it works great the way it is, A push/pull bar is only as good as the helper. I can park a tractor anywhere with this thing. up to 50 hp tractor - Cat 1 Blade
  • Like 12
Would love to see some.
In the reply box at the bottom click on "add files"
My phone then shows this
Clicking on "files" should bring up any photo you have on your phone.
Click or double click on the photo should add them to your reply.
Then click on insert to put them into the body of your reply.
16 minutes ago, Farmall Doctor said:
I have been meaning to make a tractor handler like that for some time…
if I had a blade I would make one for you . materials only. I love fabricating.
I could go one more and use fast hitch prongs… hehe
put a SGC on her and you will be the envy of Ridgetown😁.
  • Haha 3
I spent too much time looking around Clarksville AR for brake and clutch pedal springs for my 4366. They are NLA from cih. Didn't find anything exactly right but I found a screen door spring I can cut and bend new end hooks in I think. It looks correct except for length.
Then fed cows with the 826 when I got home.
Thx-Ace
  • Like 5
Last Saturday (Feb 18) I used my hydro 186#3 to load 2 loads of hay to deliver to customers.
I like to use this one to unload the trailers and stack in the dome because it has the PFC hydraulics and loader lifts a lot faster than the other 186.
 She needs a lot of love to become perfect and pretty but for now she gets the job done!
  • Like 9
18 hours ago, billonthefarm said:
Not today but this week.
It's still winter here in Canada
Moved snow again for a couple hours. 😒I'm guessing we had 8 inches or better in the last day. 0 degrees right now with about -12 wind chill. Glad the 756 has a cab with a heater.
  • Like 10
