What did you do with your Red tractor today?
DT Fan
21 hours ago, stronger800 said:
If a moldboard is about done anyway, couldn’t a guy weld a common shin piece out on the face of it? We save shins, and will quickly weld a worn set, on top of a worn set, and run them a few more days
that is what I did with the 3 bottom Little Genius, welded a used/worn shin with a similar curve, right over the front of the worn out moldboard. can't tell the difference from a new shin, after the ground is turned over.
On 11/21/2023 at 7:48 AM, Absent Minded Farmer said:
Not to cause alarm, but fleabay was not what came up from that link.
May want to take care of your cookies.
I’m about 15 miles from Ellis Grove, don’t know that guy. Buchheit is a farm store in southern Illinois and south east Missouri, so it’s a local name.
Jinxed myself. Thanksgiving day I did my annual slacking and removing links from the apron chain on the manure spreader and readjusting.... broke a link on a slat the next day🙄
Guess the links on the slats wear significantly more than regular links which makes sense. Spreader is only 6 years old. At least it wasn't -20 out
Don't mind the ratchet strap the hook is ripped off the ratchet end so this will be a good use for it and keep the come-along I normally use from getting messy
  • Like 6
Bout broke my shin getting on the H!! Stupid snow. Just needed to back it out o f the shed to put some stuff in there. Found blood when I took my boot off just now. First time I've worn that pair of boots in several years, forgot how slick they can be. Front and center in my mind now!
  • Sad 4
5 minutes ago, iowaboy1965 said:
Moved some equipment around the yard and put it back in the she's yesterday with he 400. No pics.
Ditto We now have about an in. of snow here in central Mi. Still lots of corn out.
I finished repairing my snowplow and mounted it on the 1256.I am kind of superstitious if I am fairly ready maybe I won't need it much on this El nino year.
  • Like 10
Drove the old 656 home from a job site 18 miles home from a job site. Didnt make sense to hand unload the trailer haul tractor home. Then go pull the brushhog home with the truck at 20 mph.
  • Like 8
That guy used to advertise in a magazine I used to get. I don’t know anything about him other than he does or did have a lot of plow parts.
Finally got round to putting a new alternator on the H. Got it all hooked up, still not charging. Going to have to go to a 3 wire set up I guess. Had to do that on my Cub a few years ago, and can't remember exactly how I did it. Sure wish I'd write things down!
Mac
On 12/8/2023 at 1:25 PM, DT Fan said:
Servicing the 10. It was due for an oil change so I did that and fuel filters. Had been holding off until I got the Viscosity oil last week from the Farmall Shop.
The place that fixes the temp gauges?
On 12/6/2023 at 10:08 PM, FarmerFixEmUp said:
Got the 5488 and disc chisel going again. Can't beat 50 degrees in early December! I have a feeling we'll end up paying for the nice weather later on.
KIMG0334.thumb.JPG.59c1eaa62aebc416b08cc9d88a6e2e12.JPGKIMG0333.thumb.JPG.31e14c3446172a86dd3b11727d5ca69c.JPG
What size disc chisel is that and how does the 54 handle it? Pretty good it looks like
9 shank Glencoe soil saver 3. Have pulled it with my 5288 and also a 1466.According to gps I am going about 4.5 mph and about 6 inches deep. Hard ground you definitely notice more wheel slip.
Cool my dad doesn't think ours will pull one. 4" twists?
I have a couple sunflower 9 shanks.  One has 4” the other one 3 1/2”.  Pull one with the 5488.  Handles it very nice even in tough going.  The other one have pulled with the 1486, 1466, 8920.  8920 does fine.  The 14’s do it but not super easy in tougher going.
  • Like 5
Will it pull it 8-10" deep? If not, how deep?
