sandhiller Posted August 2 Share Posted August 2 With all the rain we've had the driveway was getting some pretty deep ruts in it. I took the 966 with dozer blade and 3pt Gnuse bucket and hauled in sand and bladed it back to passable. Widened it out some too.. Really need a load of rock to shore it up. Yarded bales with the 656H Until i noticed hyd oil coming out from under the battery and it wouldn't go in forward very well, but was able to back it home. Because I don't know the actual name, I will call it a signal line for forward, had cracked a fitting I didn't have to go far for a replacement line as I just happen to have a salvage 656H. (framed in the grapple) The line I salvaged looked way more better than the one with the cracked flare fitting I replaced And I was able to be back up and running with no cost but some time. 13 Quote Link to comment Share on other sites More sharing options...
nepoweshiekfarmalls Posted August 2 Share Posted August 2 12 hours ago, mader656 said: Finally can respond to this topic...a little mowing and tractor drive. After completing a inframe overhaul...the mower is the hardest way ive got to work it. Glad to see you have the 656 back up and running, Mader! 2 Quote Link to comment Share on other sites More sharing options...
DT Fan Posted August 2 Author Share Posted August 2 Got the 856 up to the show grounds. Stopped the local tire shop to see about getting that flat fixed. Hole in the sidewall, junk tire. He had a new one, got out of there for $166, didn't think that was too bad. 3 Quote Link to comment Share on other sites More sharing options...
gafarm49 Posted August 2 Share Posted August 2 did some mowing with the 1586 9 Quote Link to comment Share on other sites More sharing options...
bkorth Posted August 3 Share Posted August 3 Sure looks green out your way, we could sure use a drink here. Quote Link to comment Share on other sites More sharing options...
bkorth Posted August 3 Share Posted August 3 18 hours ago, sandhiller said: With all the rain we've had the driveway was getting some pretty deep ruts in it. I took the 966 with dozer blade and 3pt Gnuse bucket and hauled in sand and bladed it back to passable. Widened it out some too.. Really need a load of rock to shore it up. Yarded bales with the 656H Until i noticed hyd oil coming out from under the battery and it wouldn't go in forward very well, but was able to back it home. Because I don't know the actual name, I will call it a signal line for forward, had cracked a fitting I didn't have to go far for a replacement line as I just happen to have a salvage 656H. (framed in the grapple) The line I salvaged looked way more better than the one with the cracked flare fitting I replaced And I was able to be back up and running with no cost but some time. Oops, messed that up. Sure looks green out there, we could sure use a drink here. 1 Quote Link to comment Share on other sites More sharing options...
sandhiller Posted August 3 Share Posted August 3 11 minutes ago, bkorth said: Oops, messed that up. Sure looks green out there, we could sure use a drink here. You will never hear me complain about rain But.... There is a lot of hay ground under water It rains almost every night. We have a historical ave of about 18" of precipitation a year. We are blowing that out of the water this year (pardon the pun) Pastures sure look good though🤠 1 Quote Link to comment Share on other sites More sharing options...
sandhiller Posted August 3 Share Posted August 3 16 minutes ago, bkorth said: Oops, messed that up. Sure looks green out there, we could sure use a drink here. If I could find a way to get it to you I would let you this one comin in tonight Quote Link to comment Share on other sites More sharing options...
DT Fan Posted August 3 Author Share Posted August 3 Send some our way! 2 Quote Link to comment Share on other sites More sharing options...
acem Posted August 3 Share Posted August 3 Raking and baling hay. Actually I'm reraking dry after baling baleage wet because there looked like a lot left. It didn't turn out to be much... It was 103F, 113F heat index (national weather service official) but I'm on the open tractor... 8 Quote Link to comment Share on other sites More sharing options...
stronger800 Posted August 3 Share Posted August 3 I got upset with the phone company or the cable company, I’m not sure which one over their placement of this wire. Had I been having a bad day, I would’ve relocated that to a terminated coil on the ground for them Quote Link to comment Share on other sites More sharing options...
acem Posted August 3 Share Posted August 3 Take a rope and tie it to the cable above it if they're both communication cables. Quote Link to comment Share on other sites More sharing options...
Bgriffin856 Posted August 4 Share Posted August 4 Seems like I get to use this tractor the most 5 Quote Link to comment Share on other sites More sharing options...
acem Posted August 5 Share Posted August 5 Mowed with the 1086 round noon. Baled with the 886 starting at 5pm. I was almost done and the baler quit. It was dark but it appears the upper belt drive roller shaft broke... 4 2 Quote Link to comment Share on other sites More sharing options...
Wes806 Posted August 5 Share Posted August 5 Back to doing some more bush hogging with the 806 and 8 ft wood's bush hog. 9 Quote Link to comment Share on other sites More sharing options...
MT Matt Posted August 5 Share Posted August 5 Mowed the local airport the last two mornings. It was bone dry so I only mowed early. It takes 5 passes around the runway and taxiway to cut far enough back for them. Takes about an hour a pass with the Cub and belly mower. It doesn’t look like much to mow but yellow clover grows along the edge for the first three passes, usually about 4 feet tall. 9 Quote Link to comment Share on other sites More sharing options...
billonthefarm Posted August 6 Share Posted August 6 Worked on putting this one back together. This is the fun part. 13 Quote Link to comment Share on other sites More sharing options...
Alan Dinan Posted August 6 Share Posted August 6 3 minutes ago, billonthefarm said: Worked on putting this one back together. This is the fun part. SHARP!!! 2 Quote Link to comment Share on other sites More sharing options...
Sledgehammer Posted August 6 Share Posted August 6 4 minutes ago, Alan Dinan said: SHARP!!! X2 1 Quote Link to comment Share on other sites More sharing options...
acem Posted August 6 Share Posted August 6 25 minutes ago, billonthefarm said: Worked on putting this one back together. This is the fun part. Nice looking tractor. I've never seen a 1466: with narrow axles. Quote Link to comment Share on other sites More sharing options...
Rusty_Farmer Posted August 6 Share Posted August 6 Sprayed the last field of beans this morning with the 856. 5 Quote Link to comment Share on other sites More sharing options...
IHandJDman Posted August 6 Share Posted August 6 Took the 1456 to a show and on a tractor drive. I pulled it later and ran it on the dyno. 6 Quote Link to comment Share on other sites More sharing options...
560Dennis Posted August 6 Share Posted August 6 Mounted the corn planters on the Farmall C to take it to the Ashtabula county fair. Boo yah! 6 Quote Link to comment Share on other sites More sharing options...
billonthefarm Posted August 6 Share Posted August 6 17 hours ago, acem said: Nice looking tractor. I've never seen a 1466: with narrow axles. The optional “long” rear axles are very uncommon in this part of the world. Hardly ever seen on 66’s. 1 Quote Link to comment Share on other sites More sharing options...
Sledgehammer Posted August 6 Share Posted August 6 18 hours ago, billonthefarm said: Worked on putting this one back together. This is the fun part. Is that the early serial # 14? Quote Link to comment Share on other sites More sharing options...
