Blee25 Posted April 28 Share Posted April 28 Got home after work and mowed the yard with the C and woods 306 mower. They do a pretty nice job. 10 Quote Link to comment Share on other sites More sharing options...
Blee25 Posted April 28 Share Posted April 28 (edited) Double post sorry Edited April 28 by Blee25 Double post Quote Link to comment Share on other sites More sharing options...
ole 815 Posted April 28 Share Posted April 28 Gave the Ole Gal a bath. Gotta pull wheel off. Axle seal leaking. 9 Quote Link to comment Share on other sites More sharing options...
TN Hillbilly Posted April 28 Share Posted April 28 2 hours ago, Blee25 said: Got home after work and mowed the yard with the C and woods 306 mower. They do a pretty nice job. That's a lotta yard to mow! Here, I'd be mowin that for hay. Nice lookin C and mower. I would like to find a belly mower for my C sometime, so far opportunity and money haven't been right at the same time! 3 Quote Link to comment Share on other sites More sharing options...
Rusty_Farmer Posted April 29 Share Posted April 29 Spit out about 45 acres of round up on 3 different farms over 15 miles one way. One huge 6.7 acre field needed full coverage.................😬. The rest was just head lands and around drains etc.. Started to rain on the last 3 miles home. Starting to wonder if a cab on a HI-Clear would work with saddle tanks ? 2 Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted April 29 Share Posted April 29 Tree and bed mulching day..... 10 Quote Link to comment Share on other sites More sharing options...
gafarm49 Posted April 29 Share Posted April 29 someone left it switched on ( might have been me ) 8 1 Quote Link to comment Share on other sites More sharing options...
DT Fan Posted April 29 Author Share Posted April 29 6 hours ago, gafarm49 said: someone left it switched on ( might have been me ) Found the same thing with the 856 today! 2 2 Quote Link to comment Share on other sites More sharing options...
billonthefarm Posted April 30 Share Posted April 30 Planting today. Had a photo op. Couldn’t pass it up. 16 Quote Link to comment Share on other sites More sharing options...
Wes806 Posted April 30 Share Posted April 30 Put a round bale out for the horses today with the 756 gas. 5 Quote Link to comment Share on other sites More sharing options...
DT Fan Posted April 30 Author Share Posted April 30 Did a little discing with the 10, preparation for bean experiment. Did the little patch I'm going to plant 14" rows with the All-Crop drill with the 475. Looks like it should plant real nice. Then changed to the 490 and did a 14 acre field just to see how that will compare to the no-till ones. Conditions were near perfect when I started. Got about 1/4 done and it started spitting rain, kept going.By the time I finished it was getting a little slimy! Still dust coming up and worked good but don't think I could have run another 20 minutes. Later got the cyclo mounted, hopefully get some new parts on it today. 11 Quote Link to comment Share on other sites More sharing options...
IH Forever Posted April 30 Share Posted April 30 22 hours ago, Mr. Plow said: Tree and bed mulching day..... What model is the CC on the wagon? And I assume the running gear is something you made? Quote Link to comment Share on other sites More sharing options...
mikem Posted April 30 Share Posted April 30 19 hours ago, gafarm49 said: someone left it switched on ( might have been me ) Dang shop gremlins!!!!!! Mike 2 Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted April 30 Share Posted April 30 1 hour ago, IH Forever said: What model is the CC on the wagon? And I assume the running gear is something you made? 1/2 1872 and 1/2 1882.... cyclops rear end, fenders, and fuel tank with 82 series tin work and diesel battery tray. Trailer is a Kory 3000# gear with custom made hydraulic wagon hoist and 4x7 foot dump box. Will lift/dump 2000# to 50 deg with 800 psi hydraulic pressure. Friend did the tractor conversion.....I may do the same to my 982 this winter. Wagon hoist and bed I made. 2 Quote Link to comment Share on other sites More sharing options...
Long Farms Posted April 30 Share Posted April 30 Worked some rough ground. Disked 3x and cultipacked. Disked and smoothed out cow trails. Added some jewelry to a 1456. 19 Quote Link to comment Share on other sites More sharing options...
Reichow7120 Posted May 2 Share Posted May 2 Cant get it to stop raining so i hauled corn out of the bin between showers 6 Quote Link to comment Share on other sites More sharing options...
IHC_1470 Posted May 3 Share Posted May 3 Been working on the 3588 I picked up last summer. Been working on electrical issues. Think I have most of them sorted out, a little run time will tell the story on that. The digital tach has not worked correctly in the time that I have owned the tractor. I knew the connector on the RPM transducer was messed up, it had been converted to butt connectors and they were in poor shape. So replaced the transducer, about two feet of that harness as I found a broken wire higher up and put the correct connector on the new harness. Tach worked about 70 percent of the time but was still dropping out. Some more digging and I discovered that the fuse holder for the tach was not making a good connection all the time. While working on that I noticed that the cab relay was powering up and down. Tracked that down to a bad 80 amp fuse. Someone had gotten creative in the past. Seems like it would have been just as easy to have replace that fuse with the correct one. But no they adapted a fuse and the solder connection had failed. Repaired the harness under the cab floor several wires had missing insulation so spent some time repairing those issues and wrapping the wires with new tape. Think many of those issues were from the oil leaks that were soaking the harness. The steel tubes for the steering and brake supply are long since gone and have been replaced with poorly routed hoses. For now I repaired with more hose but in the future will replace with the correct lines. The other issue was very poor brakes. Figured that out last summer, just did not have the time to replace them. Poor might not be the best word to use, when I got into them they were really beyond poor. As you can see in one of the pictures one lined plated is stuck to a steel plate resulting in the splines disappearing. I can not pull the two plates apart either. Engine gauges left me wondering what they were really trying to say. For instance key on engine off and cold would give you a oil pressure reading of around 15 psi and water temp reading about middle of the cold band. Pull wire on oil sender and gauge would drop to zero so replaced the sender. Water ended up being both gauge and sender. Hopefully things will be a little more dependable now. I am sure there is still a bug or two that need squashed. Still planning on a LED upgrade for the light. At least I have them all working. Need a good bath so I can see if there are still leaks or if I have them stopped. And somewhere in all that I need to get auto steer installed to keep the help happy. She has a new radio to listen to so what more does she need? Still have the original IH radio if anyone is interested in it. 2 Quote Link to comment Share on other sites More sharing options...
snoshoe Posted May 3 Share Posted May 3 Getting ready for season six with the number3 planter. 6 Quote Link to comment Share on other sites More sharing options...
Jake19917561 Posted May 4 Share Posted May 4 Been working ground 7’ offset disk one pass, grass is over 5’ tall almost 6’ along the river bank.The grass Loves the silt on the back of the fields by the river. 3 Quote Link to comment Share on other sites More sharing options...
acem Posted May 4 Share Posted May 4 Planting (sun) flowers with my 826 and 900 plate planter. Finished up this evening. Time to start planting rice and beans! 8 Quote Link to comment Share on other sites More sharing options...
MacAR Posted May 4 Share Posted May 4 11 hours ago, acem said: Planting (sun) flowers with my 826 and 900 plate planter. What do you do with them, sell them for the oil? Or are they more for the wildlife? Not a common crop in our part of the world any way you look at it. I managed to get my popcorn and watermelons planted yesterday. Used my little 340 utility and the Allis 1 row planter to put the popcorn in. It's a little slower, but I think it plants a little better than my IH 2 row. The watermelons I did with an old hand planter and a nail apron full of seeds. Sorta surprising how much ground you can cover in a short time that way. Also got the little bit of kitchen garden in for Mrs. Mac, or as she calls it her "salsa garden". All I've got left now is the cotton, a few pumpkins, and planting a few runner beans in amongst the field corn. Looks like rain for the next few days, so it may be a little later than I'd like before I get done. Mac Quote Link to comment Share on other sites More sharing options...
snoshoe Posted May 4 Share Posted May 4 Dug the #3 three out. Got it lubed. A green one pulled it for the planting though. Planter works great I think. Only missed 2 spuds 5 Quote Link to comment Share on other sites More sharing options...
acem Posted May 5 Share Posted May 5 The sunflowers are for primarily hunting but if there are any left I will harvest them for feed. Good luck with your cotton. You need a cotton picker now! I planted some rice on the 826 until I got soaking wet and quit. My wife sprayed burn down and premerge herbicides on the flowers. Here's a pic of her spraying. 3 1 Quote Link to comment Share on other sites More sharing options...
billonthefarm Posted May 5 Share Posted May 5 Planted 90 acres of corn with this one today. Beautiful day! 9 Quote Link to comment Share on other sites More sharing options...
MacAR Posted May 5 Share Posted May 5 1 hour ago, acem said: Good luck with your cotton. You need a cotton picker now! Thanks! I don't reckon I'll ever get a cotton picker, but I did get 2 new pick sacks Sunday. Friend of mine bought them for me at a recent estate auction, $25 each and don't look like they've been used much if at all. I happily paid him for them, since I figured I'll never see another one in as good shape let alone two! Decided to put one up for safe keeping and keep one out to pick in this fall. Funnily enough I don't mind picking cotton, or corn for that matter. It's methodical and strangely calming. Same with hoeing; ain't much better than a sharp hoe, a chew of Beechnut, and a long shady row of corn or cotton late in the evening. Mac Quote Link to comment Share on other sites More sharing options...
