What did you do with your Red tractor today?
DT Fan
Plowed a little snow today. MX 230 with a front 3 pt 11' Flink plow
Put the bush hog on the 756 to go up in the woods. Then went to a consignment sell. Watched a M sell for 1500.00 and a 1086 with duals sell for 15750.00. The Mwas in decent shape . The 1086 lookrf to have painted with spray cans no decals otherwise ran good as did the M.  If I'd had the cash the M would of had proably came home with me.
3 hours ago, gafarm49 said:
I bet you are enjoying the temps
You bet! Just got to Orlando. I don’t care to do that drive ever again. Good grief!
almost forgot, moved the A and 404 useless tillity  into the shop this morning. Bought these last fall and today was a good day to bring them home.
I used them both yesterday to deal with the remains of the system Cobfly shared . I plowed the road to the highway with my 434 and cleaned my yard again with the 1256.Plow on the 12 lost a gearbox bearing so it is only there for traction.
I believe that the highway was blocked in several places in the 12 miles from town to the border. IMG_20230311_174610.thumb.jpg.7ced4c431991fea5fd715791f9667d07.jpg
  • Like 6
Moved snow... My driveway is in front of the tractor and ends at the little tree up toward the wind turbines toward the center of the bottom picture. Not the pine tree by the truck at the left but the tiny ash tree 1/4 mile away between the 2 towers.
  • Like 7
Fed cows again...
And I loaded hay for my neighbor who's loader tractor is down.
The driver backed his truck a full 1/2 mile after I loaded it to get out!
The 1256,my pride and joy was kind of ornery today. When I went to start it the starter wouldn't engage. I wasn't sure what was up so I boosted a while with no change so proceeded to get a small wrench and short across the solenoid, it took a fair bit of cranking because we have been without power since 4 this morning. I should have given it a little start fluid.
Now I can bring some split wood that is buried under a tarp closer so I can use it.
Tuesday I set out a bale for the calf and yesterday I ground a small batch of feed, today we got this late.
With temps in upper 40's we used the 100 to....................................................................................collect maple sap...........😐
Cut up the old alfalfa roots in the drive for the new shop Monday evening.  Used scarifiers on box blade.  Was still wet, but hoping having it cut and roots loose will help dry it out.....if it ever stops raining....20230320_172958.thumb.jpg.728aa57066494b32105b72dd78bb2092.jpg
  • Like 6
Finally got the block, head, and crankshaft back for the 1256 wheatland, started putting it back together and already encountered the first issue with garbage overhaul parts! The thrust bearing is either made wrong, or for a different engine? It just drops right in the cap, and block, and can wiggle it side to side.  So waiting for a bearing set! And believe it or not, this was not a reliance kit, and the last few reliance bearing kits I’ve used were actually decent.  So as of right now, I trust reliance more than this other kit! I’m pretty sure the cracks are not supposed to be part of a new bearing? 7B9ACA13-02DA-4E85-BDDC-A0D3935C94C4.thumb.jpeg.65d283e1ba0fe683bf687874fa556ca6.jpegF5665B78-2B34-4E3F-9E41-C0E3E667AD29.thumb.jpeg.e1219b69b7dc2b5ef3fedcb6d8b2df59.jpeg23F7228D-C06A-48F5-A776-37483A8CCD9C.thumb.jpeg.3eef80768ab9265b1b03705020337c1c.jpeg570685A8-B00D-46DA-8310-C044A9858408.thumb.jpeg.917a32ee7168ca5edcfff5c82e0653b4.jpeg
  • Sad 3
Hard to believe that 8 1/2” inches of snow fell in northern Illinois on March 25th , got the 154 out and plowed wet heavy snow, hope this is the end😎
I forgot to mention that I had that problem as well with the same engine mine were FP diesel bearings. I took them all out threw them in the garbage and I think I ended up with absalute?
Rain and sleet all day ,so back to work on 404 useless till itty steering. Now it does not take a half a turn of the wheel before any thing happens ,or the wheel comes off the shaft with hardly any effort.Still trying figure why I wanted one ?
Forgot to take pictures but used the 826 to drag the lil livestock trailer to the yard. Loaded up the calf and took him for a ride to see how big he is getting. A bit over 1100#. More than I was guessing. My locker doesn't like em too big so he ought to be about right when he goes.
Change of tractor 10 days ago. An Austrian CASE IH model of 68 Horsepower from 2000 was replaced by a JXU 105 model (105 U for the American market) from 2013 and equipped with a Front loader. It has 2300 hours, lots of equipment that will change my life. Hopefully it's a reliable model. Sorry it's not an International Harvester model. But I have to get an old 1958 Farmall Diesel running again. The CS 68 tractor pictured a few days before its departure with its International Harvester model 130 plow
The CS 68 tractor pictured a few days before its departure with its International Harvester model 130 plow 8:30 am waiting for the truck that will deliver the new tractor. Arrival of the new tractor
Arrival of the new tractor from dealer CASE IH
Photo of the two tractors before the departure of the small tractor on the left
Two days later the tractor begins to do its first shredding work after some small start-up problems
12 hours ago, billonthefarm said:
I put the monitor for the 4 row on the 766 and tinkered on the 1466 with the tanks.
That monitor brings back memories. That is what went with Dad’s 500 8 row. I remember it sitting on the cowl of his 1066.
