Fat Dan Posted January 31 Share Posted January 31 How I checked the timing on a dt_466 in a TD_15c dozer. TD-15c AMBAC injection pump timing Quote Link to comment Share on other sites More sharing options...
CIHTECH Posted January 31 Share Posted January 31 4 hours ago, Fat Dan said: TD-15c AMBAC injection pump timing Right beside injection, where it bolts up to housing is a pipe plug (1/2 square drive) remove plug and turn engine over until flywheel is at 18* BTDC. Looking thru hole where you removed plug you should be able to see the timing pointer aligned with timing mark on pump drive hub. This only applies if engine is running and you just want to check timing. 1 Quote Link to comment Share on other sites More sharing options...
Fat Dan Posted February 1 Author Share Posted February 1 Thanks 👍 Checking for a friend ... hard starting.. I think 🤔 He has it set at 17° and a hair. I think he had it right but someone suggested the sleeves in the injection pump might be worn. I'll let him know. Thanks Quote Link to comment Share on other sites More sharing options...
Fat Dan Posted February 1 Author Share Posted February 1 Frank does a lot of with IH. Only man I've ever seen cut a square hole with a backhoe. Anyways DigginOK mad a video on youtube, again thinks 1 Quote Link to comment Share on other sites More sharing options...
