982 headlights not lighting!
4411 sealed headlights in the grill of 982. Key switch is in the on position for lights to be on, test light shows power at all tabs at the headlights. Bulbs work as they are/were tested on 782, they light up nice and bright. Plug them into the 982 spade tabs - NOTHING.
What the heck am I missing? The tabs fight together just as tight as they do on the 782, so why is the 982 not lighting them up? Can't find a break in wire - if there was one I'm sure I wouldn't get power to the test light.
TOTALLY confused. Is old age setting in that quick on me?
Any suggestions would be greatly appreciated.
This one is really stumping me.
Just put test light on again this morning, same on both tractors. 782 has power to the one terminal only, lights work good.  But 992 has power on BOTH terminals.  Why is there power to both?  Shouldn't one be negative without power?  So what is happening with my power supply to lights?  Worked good in fall?  Pto works as it should, blower turns on and off.
So you are talking the ground to frame from battery, at back of tractor next to solenoid?
Lights are not grounded. Unplug  wires from light. Whichever one does not have power now is the ground wire and is not connected to ground. Not sure on this model. On most of my older ones. This is at front casting mounting bolt on right side.
I think what captain kirk is saying is power should go to light, then to ground using the other wire. Doubt it has high low beam arraignment but I could be wrong .
Snoshoe has an excellent idea.
No high beams on it. Straightnon and of, 11beam strength.
That just happens to be zilch right now.  😠
Make sure you didn't plug both grounds into one light and both hots into the other.
Have wires separate correctly.   Will have a look at the ground wire on the fuel tower.
