driver444 Posted January 29 Share Posted January 29 Is there any obvious way to tell if I have a Pesco or Thompson hydraulic pump on my ‘57 350u? I have to rebuild it because it’s pushing Hy-Tran into my crankcase, but they both look so similar. I know I can pull the pump and get the number, but I’ll have to move the tractor to do the job, so I don’t want to do that until I have the parts. Any help appreciated. I have the following numbers stamped on the outside of the pump, but they don’t coincide with anything that I can find. 3A2807 0510135 P2 Quote Link to comment Share on other sites More sharing options...
DWV Posted January 30 Share Posted January 30 Shape of housing is a pesco, Unless a aftermarket. Quote Link to comment Share on other sites More sharing options...
driver444 Posted January 30 Author Share Posted January 30 Thank you! No, it’s the one that came on it in 1957. Never changed. so my next question is where to get a re-seal/gasket kit. The only ones I’ve found are for the Thompson pumps. thanks again Quote Link to comment Share on other sites More sharing options...
MacAR Posted January 30 Share Posted January 30 38 minutes ago, driver444 said: my next question is where to get a re-seal/gasket kit. Don't think they exist, honestly. Probably have to make the gaskets if you want to reseal it. Mac Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted January 30 Share Posted January 30 11 hours ago, driver444 said: so my next question is where to get a re-seal/gasket kit. The only ones I’ve found are for the Thompson pumps. These pumps were never meant to be serviced so I doubt if the dealers ever officially carried parts. Quote Link to comment Share on other sites More sharing options...
DWV Posted January 30 Share Posted January 30 11 hours ago, driver444 said: Thank you! No, it’s the one that came on it in 1957. Never changed. so my next question is where to get a re-seal/gasket kit. The only ones I’ve found are for the Thompson pumps. thanks again Most pesco used the same seal front and back. Old IH number was 356887R91. Have some old notes that I didn't jot down clear enough at this date to be sure of. Looks like I used a national 471570 seal for that number. Think the original national number on 356887R91 was 450680. Some pumps had a serial break on seals. If you have two sizes front and back the other seal would be 363781R91. Same seal used in thompson at drive end. Have down a CR 8842 worked for it. Good hydraulic shop can furnish O rings. Seals and O rings are about all you can do. If pump internals are worn enough to let pump pressure get to seals they won't help. Maybe worth a try if in since new. IH used to sell a kit if housing was still okay but dropped years ago. Quote Link to comment Share on other sites More sharing options...
mikem Posted January 30 Share Posted January 30 If you get desperate I could look and see what my parts 350 has for a pump. Mike Quote Link to comment Share on other sites More sharing options...
driver444 Posted January 30 Author Share Posted January 30 Great info, thank you all. This is a very low hour tractor (around 500hrs) and the hydraulics are still very strong. I'm thinking I can get away with maybe just changing the shaft seals and I can make a gasket for the front cover and distributor. If I came across a Thomson pump that wasn't internally shot/worn, at a reasonable price, are the dimensions the same? meaning would I still be able to use the 2 original hard-lines from the reservoir to the pump? That could be an option. And thanks for the part numbers DWV! Quote Link to comment Share on other sites More sharing options...
