Upgraded box blade.
Mr. Plow
Spent today converting my cat 0/1 box blade to a trailing model.    3pt doesn't grade well enough.   Just needs hoses and paint.
  • Like 6
Nice job Steve.  Looks good.  You figure you'll need to hang some suit case weights on the back of it?
19 hours ago, nate said:
Looks good,  and I like the fact it’s all bolted on.   May need a restrictor in the hydraulic line for better control of adjustment??
I have a needle valve if I need it......1-1/2" cylinder is pretty controllable with 1/4" hoses and 4 gpm.
It's about 450# now.....Cubs won't pull it if it cuts too well!!!! 🤣🤣🤣
2 hours ago, drglinski said:
Pretty cool.   Is there anything you can't fabricate?
Thanks.  This was a bit of a "throw it together" exercise.   I need to use it first thing this spring to cut in the driveway for my new shop.   Once the new shop it built and I can leave projects set up for a long time I might try something more challenging.
Thinking of trying a 1/2 scale grain drill, or maybe heavy offset disk.
1/2 scale grain drill would be quite a challenge! Exceedingly cool when finished.
Make a miniature JXP plow.   😄
I have a few 8" Sears bottoms.......have kicked around a 2 bottom mounted plow.   If I could find some left handers (NOT) we could work up a tumble-bug.... :) :)
I need a bigger tractor build before that build....... :)
but before that......new workshop going up thus summer......need to put down the welder and pick up the shovel and circular saw.  Scraper above will play a key roll in dirt work,  culvert install,  and driveway install. 🏠
  • 1 month later...
